Here is an unusual one. Some sort of intermittent clicking noise that appears at random intervals. Sounds metallic and is on the belt side of engine by alternator. The noise comes and goes. I have not checked the tensioners and pulleys. Here is what I know now. Tensioner is not flopping around and belt runs smoothly. Water pump is not leaking. AC works fine. Charge rate is 14.3 or so. I can get on a lift and start digging later this week. Sometimes the noise sounds like it's between the alternator and the cylinder head. It does not sound like a typical rotating part noise.
