MP517PRCT
Ok, to make a very long story short, my 2011 Touareg (133k miles) spent most of July and August at the stealership for a coolant issue (only took three trips back and forth to find/fix a bad valve in the coolant system). During this time, I'm bouncing between PA, MD, WA, Europe, and Japan for work. I finally got the T-Reg back and fixed August 16th. However, I left for three weeks in Japan on the 18th, so I really didn't have time to take it on a long drive (more than 20 miles). Got home from Japan on September 7th, and took the Touareg on a 70 mile trip on Monday (9/11). Got a CEL upon startup, checked it with VCDS last night, it was Reductant Tank Temperature Sensor P205B 00 [172] - Implausible Signal.
I checked the VW Dieselgate warranty lookup page. My Touareg was fixed on September 5th, 2019 at 116k miles. So, the 4 year 48,000 mile extended warranty expired last week. After the coolant debacle, I just want to sell this thing ASAP and get a 2015-2016 Touareg, so I am not looking to invest the money to delete it. Searching online, I can't find a DEF tank temperature sensor. Is this item part of a module? Also, is this an item that a semi competent home wrench monkey can replace?
