gurunutkins
no replies on the MK6 forum maybe someone here can help?
Hi all
looking for some advice - I have read all of the threads on this I can find and cannot figure out the problem.
I have a 2011 JSW and am getting P0087 error codes combined with the flashing glowplug symbol and then the check engine warning lamp and the car goes into limp home mode. They can come on every mile or nothing for 500 miles. In between resetting the codes the car runs perfectly until it starts setting codes again. This has been happening for the last 2500 miles. First thing I did was check for filings in the pump fuel metering valve but its totally clean.
I have read through all of the forum posts on similar problems but very few people post their final solutions. The only post that seems to have done so found that replacing the fuel metering valve on the pump worked for them. I have replaced the filter and checked the fuel lines are unkinked and free flowing. I have the ross tech cable and VCDS and my lift and aux pumps seem to be running at the right pressures so I replaced the fuel metering valve - no metal particles visible anywhere. The replacement has not helped so I need some outside help because I just hate throwing parts at a problem! I have messaged 2 micron about his technique for cleaning the fuel pressure regulator on the rail but I cant find any details to the technique. If anyone has had the same problem and solved it can you tell me what the solution is because i am banging my head against the wall on this one - I have also been through all of the posts on the MK 5 forum too and lots of people have posted the same - or similar - problems but no solutions seem to be posted - the threads just stop - any help greatly appreciated.
Cheers
Barri
Hi all
Cheers
Barri
