Hello, long time lurker, first time poster here.
I have had a 2012 JSW TDI for about 5 years now with few issues other than the dreaded sunroof leak.
I am now approaching 130,000 miles and received the following diagnosis from a VW dealer after my check engine light came on (solid,not flashing):
- thermostat failure
- DPF failure (needs replacement, failed the soot in pipe test)
- p2002 code
- missing a bolt on the turbo
- leak on turbo piping that needs repair
- misc suspension maintenance including front wheel bearings and bushings
Also, at 130,000 I need the timing belt service.
I just exited the warranty at 126,000.
The value of these repairs and maintenance exceed the value of the car and if I take the dealers pricing at face value are almost double the value of the car.
I am in an emissions check area so can’t do a DPF delete and the car won’t pass emissions as is.
Now the rub.
I think the reason the check engine light is on is because the car won’t regen because it can’t get to temp (dash gauge indicates 180 or below typically).
Yesterday I was able to get the temp up to 190 and hold it there and drive for 15-20 or so minutes. When I turned the car back on the check engine light was off. This required holding the car a gear below where it wanted to be to generate enough heat which isn’t sustainable obviously.
So….should I roll the dice and DIY or shop repair the thermostat and turbo? I have a quote from an independent shop to do the thermostat for around $800. Or is this just throwing good money after bad?
I am likely separating-from this car and likely VW vehicles that aren’t under warranty either way. I’m just trying to maximize my value for resale or trade-in basically.
- p2002 code
Now the rub.
