Tdimrtwo
I just changed the clutch on my 250k miles 6MT JSW, and now the clutch won’t release completely. So I replaced the clutch master cylinder, thinking it might be worn, but after hours of bleeding, it’s no different than before. The clutch engages close to the floor, and I can’t shift gears or into reverse with the engine running. Is there anything I can adjust, check, or repair before I swap the clutch out again?
A little more history: I burned up the old clutch when the shift linkage came apart and the car got stuck in 5th gear. I replaced the clutch, pressure plate, throw-out bearing and slave cylinder with a spare that I had from the previous clutch job, but I didn’t replace the DMF, which had been replaced previously. The clutch that I burned up released perfectly prior to the linkage issue, so I now think the issue is the new clutch that I installed. TIA for any help or advice before I tear into it again.
