Dirtscoots
Please excuse some dumb questions. I have done a lot of searching and can’t seem to come up with answers I’m sure they must be out there. I have a 2011 Jetta tdi 165000 miles auto.
I have a fuse box under the hood also drivers side panel behind the door. Is there not a relay box anywhere? There is one relay under the hood. My issue is my climate control isn’t working correctly. The fan turns on and will make heat, but the heated seats don’t turn on, the ac doesn’t light up or work none of the switches light up on the climate control. All the fuses are good. Is there a way to test the climate control switches?
I’m new to tdi and will take any suggestions on maintenance that I’m possibly due for or overdue as well.
thank you
thank you
