I read a lot. I also service these cars. A lot. So I actually know what issues they have, and how to resolve them or at least minimize the chances of them happening.
Cracked DPFs are EXTREMELY common. So common, VAG has a TSB about it. And this was BEFORE Dieselgate. Cranking the emission controls up even tighter will only make the problem worse. And it has.
Look up the price of a DPF. Then look up the labor to R&R one.
Turbochargers. Common failure, mainly due to the stress that gets placed upon them during DPF regens. If you have no DPF, you have no regen, so no added stress on the turbocharger. Price one of those. It costs more than thrice the value of your car.
Yes, this is against Federal law, and yes, it sucks, but it most certainly DOES prevent expensive problems down the road. EGR delete eliminates the low pressure intercooler icing issue. Do you know how much it costs to replace a CJAA after the rods bend and break? I will give you a hint: a lot more than $1600.
So while I certainly am not calling for everyone to delete much of the emissions compliance equipment, I totally understand the reasoning why someone would, and it is based in sound simple math. Unlike the PDs and VEs, whose emissions equipment is trivial in comparison, and does very little real negative in the long run regarding reliability and durability, the CRs most certainly DO have an effect.
So please Mongler, unless you own one of these cars or have some real world experience with them, stick to your old stuff. It is a very different ball game, and has a very different set of problems which can be better or worse depending on your tolerance for such things.
