2010 Jetta SW TDI 3 CEL Codes, need to pass AZ Emissions
BustedTDI
Queen Creek, AZ
2010 Jetta Sportwagen TDI
So this is a new to me 2010 Jetta SW TDI, I am more familiar with ALH's. Need to pass AZ emissions, and the CEL will not stay off. Here are the error codes. Any assistance on where to start would be greatly appreciated. Thank you.
011174 - Unknown Error Code
P2BA6 - 000 - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 238615 km
Time Indication: 0
Date: 2017.02.20
Time: 11:59:34
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Load: 0.0 %
Pressure: 943.8 mbar
Temperature: 29.7°C
Mass Air / Rev.: 275.0 mg/str
Temperature: 42.3°C
006744 - Unknown Error Code
P1A58 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 255
Mileage: 238615 km
Time Indication: 0
Date: 2017.02.20
Time: 11:59:34
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Load: 0.0 %
Temperature: 29.7°C
Mass Air / Rev.: 280.0 mg/str
Temperature: 42.3°C
005079 - Cylinder 4 Internal Pressure Sensor
P13D7 - 000 - Short to Plus - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 238615 km
Time Indication: 0
Date: 2017.02.20
Time: 11:59:37
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Bin. Bits: 00001100
Absolute Pres.: 0.0 bar
(no units): -12.80
Ign. Timing: 0.0 °BTDC
(no units): 18.40
JETaah
mi 48836
96 B4V, 1999.5 jettaIV,2005 BEW Beetle
BustedTDI
Queen Creek, AZ
Fairly certain that the below code of for a bad Glow Plug. Just ordered one.
P13D7
The P2BA6 & P1A58 seem to be a bit more obscure, with no real solution available in the above links. Googled everything and it could be bad O2 sensors? Other than that, not much to go on here. This is out of emissions warranty from VW, so going to the dealer is not a viable option.
BustedTDI
Queen Creek, AZ
My thought is that I can take care of the P13D7, then I can get the emissions to regen. Does that logic make sense? Would a P13D7 cause the engine to not allow a regen?
Just want to make sure I'm coming at this with the correct approach.
Thanks.
There is a TSB about cylinder pressure sensor DTCs, and checking the data blocks while the engine is running, and wiggling the glow plug connectors. You may just have a bad connector, although those have been NLA for a while now (meaning, you might need a whole engine harness, if you can even get one of those).
BustedTDI
Queen Creek, AZ
Turned out the it was a bad glow plug. I replaced #4 and still had the code, but in typical VW fashion, instead of #4 they really mean #1. Put the glow plug from #4 into #1 and the P13D7 cleared. Now onto the emissions codes. Going to try and drive it to get it to regen. Will report back, for those that care.
DriverJon
Irvine, CA
2010 Jetta TDI, 6M
Hopefully you are aware of the process of properly "registering" (probably wrong on that term) a new injector... they have some kind of cal or grade info that needs to be entered in the ECU for best operation. Info available on the Ross-Tec site...
