2010 Jetta ABS module coding help. used module
firehawk618
Marysville, WA
2011 Golf TDI, 2dr, M6, Stock
I had the dreaded ABS module fail on a 2010 Jetta that was brought to me for ABS / traction / brake lights and dead speedometer. I got one from the junk yard with the exact same numbers and installed it.
The original module wouldn't communicate at all. The new one communicates fine, speedo works etc but I cannot code it.
It appears this is not an uncommon issue when installing the used modules.
I cannot retrieve the old coding from the original module because it cannot communicate.
Current coding is all zeros.
Any ideas how I could come up with my original coding?
Attached is a full VCDS scan.
Thanks for any advice.
Saturday,19,March,2022,13:48:59:58197
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.3.0.1 (x64)
Data version: 20220225 DS336.1
www.Ross-Tech.com
VIN: 3VWRZ7AJ5AM109014 License Plate: PAT
Mileage: 253800km-157704mi Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72 77
VIN: 3VWRZ7AJ5AM109014 Mileage: 253800km-157704miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 AG HW: 07K 906 055 M
Component: 2,5l R5/4V G 9970
Revision: G6H03--- Serial number:
Coding: 0000075
Shop #: WSC 23320 444 128274
VCID: 73EFA00D12567D17CF-8026
VINID: 0E69E2A8745A151741009001100D6F6285
No fault code found.
Readiness: 0110 1100
Address 02: Auto Trans Labels: 09G-927-750.clb
Part No SW: 09G 927 750 HG HW: 09G 927 750 HG
Component: AQ 250 6F 1631
Revision: 00H90000 Serial number:
Coding: 0000840
Shop #: WSC 00066 000 00000
VCID: 7DFB863524123B67A9-8028
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 00000000000000000000000000000000000000
VCID: 78F59721CB301E4FFA-802C
5 Faults Found:
00778 - Steering Angle Sensor (G85)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 129
Mileage: 253799 km
Time Indication: 0
Date: 2022.03.19
Time: 21:12:22
Freeze Frame:
Count: 3
Count: 12
Count: 12800
Count: 288
Count: 48384
Count: 0
Count: 256
Count: 0
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 129
Mileage: 253799 km
Time Indication: 0
Date: 2022.03.19
Time: 21:12:27
Freeze Frame:
Count: 7
Count: 12
Count: 29184
Count: 195
Count: 48384
Count: 0
Count: 256
Count: 0
01435 - Brake Pressure Sensor 1 (G201)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 129
Mileage: 253799 km
Time Indication: 0
Date: 2022.03.19
Time: 21:12:22
Freeze Frame:
Count: 3
Count: 12
Count: 12800
Count: 279
Count: 48384
Count: 0
Count: 256
Count: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 129
Mileage: 253799 km
Time Indication: 0
Date: 2022.03.19
Time: 21:12:22
Freeze Frame:
Count: 3
Count: 12
Count: 12800
Count: 295
Count: 48384
Count: 0
Count: 256
Count: 0
01423 - Lateral Acceleration Sensor (G200)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 129
Mileage: 253799 km
Time Indication: 0
Date: 2022.03.19
Time: 21:12:22
Freeze Frame:
Count: 3
Count: 12
Count: 12800
Count: 270
Count: 48384
Count: 0
Count: 256
Count: 0
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00149
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_VW36.rod
VCID: 75EB9E15D4226327E1-8020
Address 09: Cent. Elect. Labels: None
VCID: 55ABFE95BCE20327C1-FFFE
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AD HW: 1K0 909 605 AD
Component: 04 AIRBAG VW8R 036 8900
Revision: 06036000 Serial number: 003EVM02AZVJ
Coding: 0012340
VCID: 6ED9B179797450FF20-803A
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME4E307428D
Subsystem 3 - Serial number: 6342MSME4E65340CK
Subsystem 4 - Serial number: 6351HSME1F644D08I
Subsystem 5 - Serial number: 6361HSME1F641F70H
Subsystem 6 - Serial number: 63727SME20112735O
Subsystem 7 - Serial number: 63827SME2012592E$
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 053 0111
Coding: 0001031
VCID: 0201F5C95DEC449FD4-8056
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5M0 920 960 E HW: 5M0 920 960 E
Component: KOMBI H14 0112
Revision: X0014004 Serial number:
Coding: 270700
ASAM Dataset: EV_KombiUDSMM9RM10 A04102
ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
VCID: 31636A0560CA0F077D-8064
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 210110F1000897
Coding: ED807F07000602001002
Shop #: WSC 00066 123 12345
VCID: 69D3C265409AB7C775-803C
1 Fault Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 169
Mileage: 253799 km
Time Indication: 0
Date: 2022.03.19
Time: 20:28:32
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5M0 920 960 E
Component: IMMO H14 0112
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ImmoUDSMM9RM10 A01102
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6AD1BD698D9CBCDF7C-803E
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0000509788
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 2757845D5E0E41B7A3-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000004665831
Coding: 000490
1 Fault Found:
66048 - Motor for Front Window Regulator
B11EC 54 [008] - Missing Calibration / Basic Setting
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 169
Mileage: 253799 km
Date: 2022.03.19
Time: 19:52:53
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 31636A05A8CA0F077D-8064
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0000482170
Coding: 0004B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 2855876153104ECFAA-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000004679727
Coding: 000490
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0035
Revision: -----20S Serial number: VWZ4Z7K3062847
Coding: 0500040004
VCID: 61C3DA4578AAFF87AD-8034
2 Faults Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 128
Mileage: 253799 km
Time Indication: 0
Date: 2022.03.19
Time: 19:52:53
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 169
Mileage: 253799 km
Time Indication: 0
Date: 2022.03.19
Time: 20:28:26
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Part No SW: 5K0 937 085 G HW: 5K0 937 085 G
Component: RDK 111 0821
Coding: 018705
VCID: 3777541D86AED13733-8062
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000328785114
Coding: 412100
VCID: 2A517D69451C7CDFBC-807E
End-------------------------(Elapsed Time: 02:38)--------------------------
TurboABA
Kitchener, ON
RIP-2010 Jetta 6spd 2014 Touareg Execline
Here's my ex "coding", but it looks like different controllers and hardware.... feel free to try it if you wish.
Address 03: ABS Brakes Labels:. 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AK HW: 1K0 907 379 AK
Component: MK70 M MASR 0104
Revision: 00H35001
Coding: 0017665
VCID: FBFFDC3DBA73679772-80AE
firehawk618
Marysville, WA
I tried it, all I seem to get is "out of range". I might have to rip apart the old abs module on a bench, try to solder back the broken wire just to retrieve my code!
I have a J2534 and am willing to pay VW for a day access but from what i can see the procedure to get registered on their website to do this takes days!?!?!
TurboABA
Kitchener, ON
Do some searches.... I just did a bunch, and there are some calculators and paid services for generating the long coding.
You need your vin and a few other parts of the info. I would assume that VW would offer the service as well, but I'm sure it won't be cheap.
firehawk618
Marysville, WA
I will do that. I had no idea there were online calculators. I will search around. Thanks.
firehawk618
Marysville, WA
I went ahead and did the one from Carprog and also found a free one on MHHAUTO. Neither worked. I'm not sure it really matters but neither calculator lists the 5 cylinder engine as an option when configuring the code.
I'm taking a break for now and doing to do other stuff, frustration setting in!
firehawk618
Marysville, WA
Update: I was finally able to get it to accept coding.
I had to take a known config from a module with the same exact number and change the bits that contained the vin to match my vin.
