2010 in limp mode, dpf light solid, coil flashing. Please help
Bsmith677
La
2010 jetta tdi 4 door sedan 6sp MT
Former Cummins owner, I had a pumped 24v with compounds so I understand diesel enough.
I just recently purchased a 2010 Jetta tdi 6spd mt with169k. Thought it was my maf, changed that nothing.
Car in limp mode accelerates slow. I bought an egr block off plate, exhaust, diesel geek fix for intake manifold waiting for them to come in.
Codes are p2008 intake manifold runner control circuit open bank 1
P13D9 this is glow plug I think.
P0401 egr flow insufficient
P00AF boost control A module performance
P2463 dpf restriction
I also ordered a vagcom for my cpu.
I’ve searched for my codes and haven’t came up with a definite answer. Any advice is greatly appreciated.
Thank you for you time.
Bsmith677
La
I did but since the previous owner didnt bring it for a recall. I don't qualify is what the guy said when he ran my vin.
I want to delete it anyway. Just worried I have bigger problem.
Exhaust came in yesterday, flashzilla this weekend hopefully.
Talked to someone at malone, #4 glow plug might be bad. Gonna see what happens after tune an new exhaust.
Bsmith677
La
Anyone around Baton rouge, la with access to tools to change exhaust? I can do the work just don't have all the tools. I'll supply beverages and food. I'm trying to avoid driving 100 miles in limp mode. Any advice is appreicated.
Brian
Bsmith677
La
Ok so I did the stage 2, New exhaust.
Im still in limp mode. Cel on. Codes
P0220 tps a open
P2101 tpms
U2000 audio rear control not responding
BE FE1 Idk
P0544 egt bank 1
C2121 tpms
Waiting on my vag.com to come in.
Any suggestions? im really tired of driving in limp mode.
Thank you!!
jesssssser
Buffalo
2010 Jetta Sportwagen ~118K
Good luck man, seems like vagcom may solve you issue. I imagine your dpf egr clogged up. Removing and reprogramming will hopefully fix it.
PRY4SNO
Edmonton, AB
2010 GSW 6 speed
This is about all I have to offer from a quick web search, hope it clears up for you soon. I bet the car will liven up nicely once it's up to the full potential of it's new spec.
P2101
