smoothhd
I have been searching the internet all day with no good results, have also thoroughly searched here. So any help is greatly appreciated.
The low beam, high beam and fog on the passenger side aren't working. I have relamped them, to no avail. The low beam was visually bad (filament blown away) the others could see nothing wrong and had continuity thru them. Once the car is started, I get the lamp out indication on the MFD with the following lamp out messages, rt dipped light, rt main headlight, rt fog light, left turn signal light, right turn signal, and the one for the license plate (cant remember what I says exactly). The ones in the rear that I get the message for are working. Only the hi/lo and fog on right side aren't working, there is no voltage at the connectors.
Has anyone heard of or seen this before? I am guessing there is a vag reset or something that should be done after the bulb is replaced. I can find no single fuse for any of these lights, so they must be controlled from a module somewhere.
I have read about all the dipped headlight problems on earlier cars with xenon lights but I don't have those. Mine are just H7's.
Thanks for any suggestions
Brian
Brian
