I have always wandered if something like this would work on our engines.. i know it would make some placement issues.. but i wander if it would work.....
Basicly what it consist of is a smaller turbo example (vnt15)and a larger turbo as in a (vnt25-30)...
The larger turbo is bolted directly to the engine via manifold.. and the smaller turbo is bolted to the larger turbo... so the exhuast gases flow thru the bigger turbo and then thru the smaller turbo before flowing out the exhuast...
so the smaller turbo has its quick spool up rate as normal and gives you that great off the line punch.. then as the rpms climb and the exhuast gases make the larger turbo build boost the spring loaded butterfly valve is opened and the flow of boost from the larger turbo overcomes the flow of the smaller turbo taking the load off the smaller turbo...
then it goes thru the intercooler and is controlled via a manual boost controller to prevent to much high end boost.....
so basicly the whole rpms.. is covered with boost and good flow...
VNT15 takes care of 1500-3000rpms boost and then the larger VNT takes the 3000+rpms range...
