D_Bat
I didn't see the liberty on that list but I'm sure it's a 2056. The mercedes one I have is a GTA2056VK which is a.... 2nd Gen VGT? Whups, those start with 224hp. Even better.
That is how the T3 I tested for Upsolute years ago behaved (with the likely exception of the 200-hp part). It was a real hoot from 3500-4500 rpm and probably would have been a good drag car. But I autocross and daily drive and was disappointed with the big turbo's response in "normal" driving... especially the big belch of smoke accompanied by "no go" until 1000 rpm later.turbo johan said:I did a AGR 90 hp with FINturbo pnp turbo (GT2052)
I made over 200 hp but first 2 gears didn't built any boost before 3000 rpm. In 4th and 5th it spools from 2000 rpm.
So do we just need to take a european vacation and comb the junkyards for an AFN mannie or who can ship a few across the pond?jsrmonster said:Here is the early mk4 AFN110 2piece exhaust manifold. Great for A3 projects w/big turbos, and oem motor mounts ;-)
have you tried the fitment? Does it clear the motor mount by raising the turbo higher? Adapter plate is for turbo to mani, what about the dp?traxterXT said:to fit a GT2056 you can also use a Mk2 turbo diesel manifold with an adapter plate.
Ruben is the mk2 motor mount the same for the mk3 (b4 passat)? Looking to see if the turbo will clear the mount in the same manner if the manifold raises it higherRub87 said:you can just leave the mount inplace and move the turbo more backwards instead of downwards....? I'll post again a picture as inspiration
these manifolds are found on many cars, including all mk3 vnt engines (afn) and mk4 asv engines in mk3 style bodies (ibiza asv), vw passat, audi a4/a6 (110hp vp, PD100, PD130) until the recent model with transverse engine, almost all audi A4 etc etc
direct bolt on turbos are passat/a4/a6 gt1749va and the KKK turbo from a 170hp version audi A4, and with adapterplate almost any reclockable turbo is quite easily fittable
and these manifolds flow quite well when ported
Anyone have pics of this Mk2 manifold?traxterXT said:to fit a GT2056 you can also use a Mk2 turbo diesel manifold with an adapter plate.
Thats the same conclusion I had after looking at the A/R and map.hatemi said:2056 has propably the best comprossor map for a daily driver with a WG.
VW97JettaTDI said:ok after reading every ones thread i have a very diff perspective so let me try asking a dumb question.
Ok so i understand most of the turbos and primarily i need one that is simple yet fast spool with constant power. Of course i want a VGT but because AHU/1Z dont have vacume lines and what not they cant work. so why wouldnt the next best bet be a t3/t4 or even a vnt-17 i hear all this about the gt2052.. but will that be a direct bolt up or is there swaping or oil lines and such. ALSO where is every one getting all these aftermarket intake mani's from and what are you doing about the EGR, doesent your ecu freak??? any advice guys..
im looking to for max power with some stronger pistons, intercooler, intake, injectors, turbo and maybe a 11mm fuel pump!
ok, so you make it sound so easy... its normal to think this i hope. but going from non vacume to vacume wont that screw with things alot? and yes my plan is a strong engine with good milage. i dont care about power so long as its more than the wimpy 140hp four cylinders and 1.8t's/vr6hatemi said:Converting AHU to VNT is silly easy. You neeed AFN n75 valve, few meters of 3.2mm tubing for vacum lines and some T-connectors for it. Getting the vacume reservoir from ALH would also be a good idea. Then all you need is a good remap from tuner of your likeing and youre set. I'm pretty sure all of the US tuners know how to do such a conversion.
So what is your max power goal then? 200hp, 250hp, 300hp? That pretty much defines what is needed and where to go next.
You can convert to 11mm pump but youll need to change the pump bracket to one that you can fit the ALH pump in. Then youll need to redo the wiring connections since AHU has different plugs than ALH.
I change my AHU engine pump with ALH 11mm pump, i use top of AHU pump on new ALH pump to keep wiring intact, work good and trouble free.hatemi said:Converting AHU to VNT is silly easy. You neeed AFN n75 valve, few meters of 3.2mm tubing for vacum lines and some T-connectors for it. Getting the vacume reservoir from ALH would also be a good idea. Then all you need is a good remap from tuner of your likeing and youre set. I'm pretty sure all of the US tuners know how to do such a conversion.
VW97JettaTDI said:ok, so you make it sound so easy... its normal to think this i hope. but going from non vacume to vacume wont that screw with things alot? and yes my plan is a strong engine with good milage. i dont care about power so long as its more than the wimpy 140hp four cylinders and 1.8t's/vr6
has any one done the vnt 17 and been able to easily hit 200? and is that your safest bet for reliability? i want a car that i can trust wich can be a joke in the tuner world when your in experienced!
You obviously have not read several posts from various people above.VW97JettaTDI said:has any one done the vnt 17 and been able to easily hit 200? and is that your safest bet for reliability?
