maloosheck
It comes straight from VW training materials for PD170 (BMN) engine. I am afraid I have only Polish version available, but I can translate word by word if you want.lbhskier37 said:I have never heard this before.
So your saying in europe where TDIs pretty much all have DPFs, the driver is instructed to and has to drive a certain way periodcially to regenerate the DPF? This makes no sense as all the vehicles in the US that have DPFs don't have the problem.maloosheck said:It comes straight from VW training materials for PD170 (BMN) engine. I am afraid I have only Polish version available, but I can translate word by word if you want.
First, not all engine has DPFs. They were introduced recently. In the document I got there were only 4 engines with the DPF mentioned.lbhskier37 said:So your saying in europe where TDIs pretty much all have DPFs, the driver is instructed to and has to drive a certain way periodcially to regenerate the DPF?
I have no idea about US DPFs. Maybe it is a matter of amount of fuel used and emission levels?lbhskier37 said:All DPFs in the US get regenerated automatically if the driver doesn't drive a certain way. Why would VWs be any different. Are VW engineers that much below Cummins and Cat engineers?
Sounds like short trippers might have a hard time keeping this going.maloosheck said:Passive regeneration is automatic process and it takes place when the exhaust fumes temp. is 350C-500C e.g. during highway driving.
Active regeneration is performed after increasing the temperature of the exhaust fumes to 600C-650C through additional fuel injections 35degree after Top Dead Point. Unburnt fuel goes to DPF and burn the soot particles. This reaction requires certain amount of oxygen in the fumes and takes about 10 minutes.
When the filter is 50% full ECU starts active regeneration, that takes approx. 10-15 minutes.
If the active regeneration is not possible due to inappropriate driving conditions, the filter is filled to 55% and the active regerneration will last 30 minutes.
If it is still impossible to initiate active regeneration, ECU turns on the DPF light that requires driving for 10 minutes at constant speed of 60km/h.
If the driver fails to drive that way and the DPF is filled in 70%, ECU turns on the CEL, glow plugs light and DPF light. At this point active regeneration is possible only using the diagnostic tools.
I've been reading the back-and-forth on the Sportwagon thread and it's put your statement shown above in a different light. It sounds like all JasonTDI said to you is that the current particulate filters on TDIs in Europe are user-dependent. While true, you make statements in the second and third sentences of this post as if they were fact. It now sounds to me that they are opinion only, and, for that matter, opinion that involved a leap from a statement made to you about particulate filters.ssamalin said:I don't think there will be a 2009. The NOX burner doesn't meet the emissions tests and VW won't produce it. The NOX system is user dependent and therefore will not meet emission regulation. JasonTDI says the user is required to drive the car at a certain speed for a certain time. This fails regulation that the system is idiot proof. That I think is why VW announced a delay. They can't fix it and will announce no 2009 unless they can glue a urea NOXer on it. Not going to happen.
NOX burner and DPF are two completely different emmission systems on 2009s both of which I think must work without dependence on user driving speeds to pass 50 state. Both it seems may not pass that test so I conjectured that could kill the 2009. JasonTDI only refered to the NOX burner requiring driving at a certain speed and time period. Others since my post have pointed out the DPF is likewise flawed. There are no facts here only that the NOX and the DPF may be user dependent, and if I'm not mistaken, that 50 state requires no user dependence. Whether this means the 2009 is in trouble because of this is my conjecture. If as you say the DPF may not be user dependent than obviously that eliminates that. I have no news or info from any source VW or Car and Driver. I said "I think" line one.IndigoBlueWagon said:I've been reading the back-and-forth on the Sportwagon thread and it's put your statement shown above in a different light. It sounds like all JasonTDI said to you is that the current particulate filters on TDIs in Europe are user-dependent. While true, you make statements in the second and third sentences of this post as if they were fact. It now sounds to me that they are opinion only, and, for that matter, opinion that involved a leap from a statement made to you about particulate filters.
I haven't read everything there is out there on these filters, but I did understand from the VW engineer that spoke at TDIFest that the CRD Jetta emissions system is entierly new. That would mean it's not necessarily like a system currently in use in Europe that requires driver participation.
The last two sentences of your post also sound like you had info from VW regarding their ability to fix the emissions system (assuming it's broken) and that you somehow knew that there would be no 2009 VWs. Now it sounds like you have no direct knowledge of either of these data.
Please set me straight if I'm misinterpreting this. I, like others here, depend on the continued sale of TDIs in the US for their livelihood. And I'd like to know if what you posted is fact or conjecture.
This makes me glad I bought the 2006 this sounds like a very complicated system to keep fully functional and operational for the 20 years and multiple hundreds of thosands of miles that I am planning on keeping my car.maloosheck said:Passive regeneration is automatic process and it takes place when the exhaust fumes temp. is 350C-500C e.g. during highway driving.
Ditto that.06SpiceRedTDI said:This makes me glad I bought the 2006 this sounds like a very complicated system to keep fully functional and operational for the 20 years and multiple hundreds of thosands of miles that I am planning on keeping my car.
I'm in the same boat as you as far as testing in KY and whatnot. If it were me, I would wait til something messed up. Then do a turbo back exhaust with just a muffler and maybe hi-flo cat. Then turn to our chip tuners and I am sure they will have something by then.yoseppi said:My main concern is that in states that do not require emissions bull****, how can i disable this entire stupid system so I won't have to worry about it?
Seriously![]()
dhdenney said:I wish everyone would quit using this expression "addiction to foreign oil" or whatever. We'd have plenty of f'ing oil if we could drill for the stuff.
Mmm, I wish Young's still made Dirty Dick.Jibeho said:LoL![]()
I like addiction to foreign beer better!![]()
Talk to the oil companies. They're the ones standing in the way. Why would they want us to have more oil on the market? That would drive prices/profit down.dhdenney said:I wish everyone would quit using this expression "addiction to foreign oil" or whatever. We'd have plenty of f'ing oil if we could drill for the stuff.
That's such a basic argument though. Doesn't really have anything to do with it. Oil companies will make their money whether oil is $1 a barrel or $100 a barrel. Oil companies will make their money whether they are importing it from the Middle East or drilling it here. It's in their profit margin. There's not gonna be any lost revenues for oil companies in this latest crash of oil prices. My basic point was we've got oil and they're importing it. I didn't say anything about oil prices.Rod Bearing said:Talk to the oil companies. They're the ones standing in the way. Why would they want us to have more oil on the market? That would drive prices/profit down.
My dealer is Quirk VW in Braintree, MA. They are by far the largest VW in the Northeast. At the moment they have 11 TDI sedans, plus a few JSW. They even gave me $500.00 off retail a couple of months ago when they didn't have to.jaydogg007 said:Just dropped mine off at the dealership for an alignment and tire rotation. Kinda got queasy when he quoted me $140 for an alignment. So while I was waiting for my ride, I strolled the lot.
In case anyone is interested....there are four 09 Jettas at Jersey Village VW right now. No TDI JSWs...at least not that I saw.
White Loyal Edition with DSG & roof
Grey with DSG & roof
Black six speed no roof (SHARPEST LOOKING ONE ON THE LOT)
Graphite Blue with DSG, rear spoiler & roof
I didn't make note of the interior colors....too much to remember![]()
Also saw four CCs....very sharp looking cars, but they kinda look like Honda Accords in the front end. I really liked the 17" wheels they come with.
You're right, we're addicted to any kind of oil, not just foreign, however:dhdenney said:I wish everyone would quit using this expression "addiction to foreign oil" or whatever. We'd have plenty of f'ing oil if we could drill for the stuff.
Was just about to say "here too!" until I realized we're talking about the same dealer. I've tried again and again to offer them MSRP but they just won't do it. If only there weren't so many multi-million dollar ski homes here (and their spending owners), I might be able to.MTjake said:Sort of back on subject, the local dealer here continues to sell '09 TDI's for $2000 over MSRP because people keep paying it.
