Plus 3 Golfer
There seems to be a thread every week or so of members concerned about their fuel economy (FE) being too low or not what they expected. Since we don't know their driving style, driving conditions, and so forth, about all we can say is that their FE seems too low compared to ours and maybe give a few examples of our average tank FE or perhaps some MFD MPG from interstate driving.
Nearly two years ago for about 3 months in AZ in Jan-Mar 2009, I kept track of my MPG vs MPH for shorter distances (3-10 miles) as shown in the graph below indicated by the blue diamonds. I have shared some of this data before in posts but believe it may be helpful to others to put it together in a graph (a picture is worth a 1000 words).
I've also included other data from Derrel H Green and Darth Furious for comparative purposes. If others have similar data, please PM me or list the data in this thread and I will try to incorporate it in the graph. Please include pertinent info like transmission, MY, additive used, tire pressure, mods and so forth. I realize this is not a scientific experiment, but if we can get enough data from manuals and DSGs by model, I think we can have more confidence in the data. Any comments would also be appreciated.
I'll make two comments on the data. First as you can see, Derrel has installed oversize tires on his JSW which give him about a 6% lower RPM over standard tires at the same speed. His effective gearing is now taller than the 2009 manual transmission Jettas (see graph). His tires are also fuel saving tires (low rolling resistance tires). IIRC, I've read somewhere that these tires can increase fuel economy by 1-3% (don't have cite maybe someone has better info?). Bottom line is that one might expect Derrel to achieve as much as 7-9% better fuel economy as equipped. When comparing Derrel's data with my data, Derrel is getting about 10% better FE at lower MPH with the % difference tailing off as the speed increases. This tailing off makes sense since drag force quadruples with a doubling of speed such that both sets of data should converge as speed increases.
Second, Darth Furious's data appears to be extremely out of range of what might be typical. Other posters in other threads also seem to have data in this range. Darth does have some mods in addition to the Revo tune.
This is the procedure I used in gathering my data:
Does anyone know if the gearing for the 2011 Jetta TDIs is the same as 2010?
- Allowed my car to reach operating temperature (usually took about 7 miles @ 45 MPH for the temp gauge to reach 190*F). Even though the temp gauge showed 190*F, the oil temperature probably was still below operating temperature so I didn't start recording data for about another 5 miles or so.
- Find stretches of highway of at least 3 miles that are fairly flat and where I could maintain a constant speed. This is fairly easy for me in the Valley of the Sun but I still checked my topo maps since I found a slight gain or decrease in elevation can significantly alter the data (eg. 50 feet/mile change can increase or decrease MPG by about 5 -10 MPG depending on speed).
- Set cruise control at speed to be tested via GPS and zero out the MFD1 data to begin the test.
- Record at least MPH and Average MPG from the MFD1 at the end of the run.
It really helps to have another person in the car to record the data as the data can change quickly as one changes speed. - Repeat the test over the same route in the opposite direction. If the MPG difference between this run and the previous run was not within about 12 MPG, I didn't use the data. Either elevation change, DPF regen, or strong winds probably affecthed the data.
- Average of the results at each tested speed. After accumulating data from about 10+ two way runs (ie, both directions), I did a simple average of the data. When I compared all two way runs, the data at a specific speed was within a 2 MPG bandwidth of the average. For example, if the simple average MPG was 50, the high two way pair was less than 52 and the low two way pair was greater than 48.
