n1das
- Joined
- Jun 11, 2002
- Location
- Nashua, NH, USA
- TDI
- 2014 BMW 535xd ///M-Sport, 2012 BMW X5 Xdrive35d, former 3x TDI owner
Only 22k miles on my 2010 JSW TDI since August 2010.
You can look on the fuelly site and look for cars with a significant number of fill ups; click on that particular car and it will tell you how many miles tracked.
Please post your odometer readings.
I am wondering how many vehicles have over 100K miles (160K kilometers)?
There should be some 2009s and just perhaps an early 2010 that have been driven that far?
D
Just drove through 50,000 miles. Changed my tires and am chugging along . . .
For example, here are all the '09 TDI Jettas:
http://www.fuelly.com/car/volkswagen/jetta/2009/diesel l4
One '09 on that list (as of today) had 290 fill ups for 140,387 miles.
About 44,200 miles since Sep 09.
Still on the original Hankooks, 4 oil changes, 2 Fuel Filter changes,
and a rear set of pads at 30k. Averaged 44.1 on my last tank.
I really need to get on this Fuelly site.
The issues I've had as follows: Ignition switch replaced right after I took delivery as door locks didn't work correct. Around 40K had a motor go bad on a "flap" in the emission system... extended warranty took care of that. At 92K I had the factory recall done to replace the Mechatronic unit (that was just this week)... I am on my second set of tires, and still running the original brakes which have plenty of life remaining.
Wes, thank you for your post. It is good to know that there are a few at least
who are getting up there as far as odometer readings are concerned.
Have you had any major problems? Are you using any additives?
D
Surprisingly, no. All highway miles. My commute to school is about 150 miles round trip, was doing that 4x a week this spring. Now, starting June 6th, Ill be doing that same round trip 5x a week for summer session! That's 3750 miles in 5 weeks...Anyways, I told the dealer at my last oil change to check my parking brake adjustment. They said it was fine.
Nothing to it, getting all set up on the Fuelly site. It's like everything else;
Once you have done it, it's easy! Just takes a little time at first.
Mostly local driving with some stop and go? Figured that because you needed rear brake pads early.
D
Sheesh, time to look into hotels with cheap weekly rates :/Surprisingly, no. All highway miles. My commute to school is about 150 miles round trip, was doing that 4x a week this spring. Now, starting June 6th, Ill be doing that same round trip 5x a week for summer session! That's 3750 miles in 5 weeks...Anyways, I told the dealer at my last oil change to check my parking brake adjustment. They said it was fine.
I'm at 49,850 miles right now. Having my oil changed next week.
