Plus 3 Golfer
If appears that's the consensus of Bosch, Dephi, Continental, Stanadyne and Denso.
I know there's a lot of threads on using fuel additives including biodiesel in the common rail CBEA engines to increase lubricity but I don't recall seeing this Sept. 2009 position paper referenced anywhere. http://www.bosch-kraftfahrzeugtechnik.de/media/pdf/themenimfokus_1/FIEM_Common_Position_Statement_2009.pdf
The salient parapgraph is:
IMHO, this is the strongest statement yet that one should be using additives in the 2009 and 2010 TDIs to increase the lubricity of the ULSD currently being sold in the US.
The last sentence is a very strong statement: "It is expected that the useful operating lifetime of any mechanical component will be adversely affected by fuel with a lubricity exceeding 460 microns." Also, notice the advice that the first fill of fuel should have a lubricity of less than 400 microns. I'll bet these companies have studies supporting this consensus statement. I would love to hear VW's response to this. I don't know the authors' intent of this sentence but to me it's clearly an indication that we should expect earlier failures of the HPFP if we use ULSD only, the ASTM specs should be changed, and lubricity additives should be used. Also, I seem to recall that Bosch supported the ASTM standards and even participated in the development (briefly searched but can't verify). Could this be a reversal?Lubricity:
It is essential that the lubricity of the fuel as measured by the HFRR test specified in ISO
12156-1 meets the requirement of a wear scar diameter not greater than 460 microns. In addition, it is
recommended by the Diesel FIE manufacturers, that “first fill” of the fuel tank should be with fuel with
good lubricity characteristics (HFRR < 400 μm) in order to guarantee good “run-in” of the injection system
components. The US diesel specification (ASTM D 975-09) includes a lubricity value of 520 μm maximum
(according to ASTM D 6079). It is expected that the useful operating lifetime of any mechanical
