2006 TDI Jetta Transmission gear indicator flashing - cranks but won't start
studio
Oklahoma
2006 Jetta
Have a 2006 TDI Jetta was and it died and had to tow it home. The gear indicator is flashing, it cranks but will not start. I bought the cheap version of the tester and here are the results. I would like to reset it such that I start it and sell it. Any help is appreciated.
This is all I get on the autoscan. Sorry if I posted in the wrong place.
VAG-COM Version: Release 409.1-US
Chassis Type: 1K - VW Golf Mk5
Scan: 01,02,03,08,09,15,16,17,19,25,37,3D,42,44,46,52,55,56,62,69,72,76,77,7D
Address 02: Auto Trans
Controller: 02E 300 042 H
Component: GSG DSG 070 0913
Coding: 0000020
Shop #: WSC 00066
1 Fault Found:
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 000 - -
Skipping Address 15-Airbags
End --------------------------------------------------------------------------------------------------
csstevej
north nj
2001 golf tdi 4 door auto now a manual, mine, 2000 golf 2 door M/T son's,daughters 98 NB non-TDI 2.0, 2003 TDI NB for next daughter, head repaired and on road,glutton for punishment got another tdi 2001NB,another yellow tdi NB , added an 06 NB DSG
Did the fuse blow again when you replaced it ?
.. if yes then start tracing wires and see where it’s shorting.
Yeah, you really are not giving us much to go on here. Clearly the Engine Controller, for whatever reason, is not powering up and/or communicating with the other modules. It lives up the cowl area, I'd take the wiper arms off and take the cowl cover out and investigate up in there for tree debris or rodent damage to the ECU's car side harness.
...if only someone would give you some sort of suggestion...
Oh, wait, ...
studio
Oklahoma
2006 Jetta
Got it out and looked it over, disconnected and reconnected, ran the VagCOM again with the same results??
Fuses are good.
studio
Oklahoma
2006 Jetta
Sorry to ask, what are the conditions under which I check for this? ECU connected? unplugged? Key on?
studio
Oklahoma
2006 Jetta
If I disconnect the ECU and turn the key on I have no voltage at the B+ and GND. Wiring diagram?
Yes, best bet to get the diagram out and check all that basic stuff. Ground is constant, there's no switched grounds to the main leads to the ECU.
You may also want to pull the underhood fuse plate up and look under there for any signs of corrosion.
studio
Oklahoma
2006 Jetta
Found one, is a ECM the same as the ECU?
On the drawing is a DFI Engine Control Module is this it?
Is there a way to post pictures directly?
studio
Oklahoma
2006 Jetta
Was able to get this today, still flashing, not sure my next step?
VAG-COM Version: Release 409.1-S
Coding: 0000020
Shop #: WSC 00066
6 Faults Found:
P1850 - 000 - -
18270 - Shareware Version. To Decode all DTCs
P1862 - 000 - Please Register/Activate - Intermittent
18288 - Shareware Version. To Decode all DTCs
P1880 - 000 - Please Register/Activate - Intermittent
18275 - Powertrain Data Bus: Missing Message from Steering Wheel (J527)
P1867 - 000 - - - Intermittent
18274 - Shareware Version. To Decode all DTCs
P1866 - 000 - Please Register/Activate - Intermittent
18082 - Shareware Version. To Decode all DTCs
P1674 - 000 - Please Register/Activate - Intermittent
ECU/ECM/DFI is all the same thing. It is the controller that is for the engine, living up in the cowl. Has two connectors, one goes out to the engine itself, for all the things on the engine, and the other goes to the car side, and heads over and through the bulkhead area into under the dash.
csstevej
north nj
csstevej
north nj
Is that a legitimate Vcds ? Or a knock off…… it keeps asking to register/activate .
studio
Oklahoma
2006 Jetta
Yes it's a $10 item. Sorry I was out of town for a few days. I was afraid to rent one like from Ebay for fear of how long it might take to fix it. Open to suggestions.
