dustystdi
Background:
I have a 2006 tdi jetta that I bought from a friend that has been sitting for about 6 months. When I picked it up this past weekend it had about 4 inches of water in the floor due to leaking sunroof. I vacuumed, removed all carpet and floor vents. I have been running dehumidifier for 3 days. I disconnect battery every night to try and let it reset.
Issue:
The car starts and then shuts off after one second due to immobilizer problem and maybe something else.
Symptoms:
1) I connect battery and turn the key switch on, the only indicator lights I get on the cluster are the DRL, brake pedal for shifting, and faulty parking light bulb. I crank the car and it fires right up then shuts off. Repeat over and over and over again throughout the day and it never changes.
2) I connect battery, turn key on same indicator lights on cluster, if I turn the headlight switch on, the cluster blacklights illuminate but I loose the 3 lights.(drl, brake pedal, bad bulb). If I turn headlight switch back off the lights reappear. Tried cranking in both positions again and same thing happens. Starts, runs 1 second then dies.
3) After the first night of running dehumidifier all night I had something happen the next morning that only happened once and I have not been able to replicate. I connected battery turned key switch on and all the indicator lights came on the cluster like it would if the car was acting normal, (glow plug, abs, traction control, brake, check engine, immobilizer, etc.) I then cranked the car and it started and ran perfect until I shut it off about 5 min later. Tried to start it again and back to the 3 lights and starting for 1 second and shutting off.
So far:
1)I have removed the cluster cleaned reinstalled
2)Removed and reinstalled all relays and fuses
3)Removed and cleaned ECM harness
4)Removed and cleaned Central control module under driverside dash.
If anyone has any suggestions please help me.
Issue:
Symptoms:
So far:
