I did a fair amount of work replacing engine components last year when my piston rings wore out, and everything went fine for about 10,000 miles when I started hearing an extremely faint ticking sound while on the freeway. I pulled over and by the time I came to a stop the engine had all but seized up.
I towed it home and the engine turned fine manually, the timing was fine, cam looked fine, so I tried turning it over with the glowplugs removed and it did so for about 3-4 seconds before seizing again. Pulled the camshaft, and it still would not turn a full revolution manually. I pulled the head expecting to see debris in cylinder #4 and an absolutely destroyed piston/valve, but all I saw was a very, very slightly dinged up #4 piston and valves that showed no sign of impact, but the #4 piston was visibly protruding ever so slightly more than the other 3.
I pulled the oil pan and found the #4 conrod bearing (all were replaced along with the main crank bearings last year) had spun around so both halves were on the top of the bore, so the ticking wasn't piston to valve contact...the connecting rod effectively got a little longer and it was piston to head contact. Fun.
At this point I'm working out what to replace, and the head and all pistons look perfectly serviceable to me. The crank is chewed up enough on #4 that I'm thinking it won't be worth trying to salvage without taking it in to get it machined, and I can probably just get a used crank with half the mileage for half the price.
So, onto the questions...
Is a conrod with this kind of bearing damage salvagable? It's not bent, but the big end has some obvious galling from rubbing on the bearing material, though I don't think it has chewed up the conrod material itself. Is it possible to get the big end back in spec with either basic tools at home (i.e. hone + bore gauge) or taking it to a machine shop, or is that just not possible once something like this has occurred? I'd like to avoid replacing it if possible since I just replaced all 4 conrods as a set, but if it's doomed to fail again...
Is replacing a crankshaft as simple as swapping it out, or is there some kind of gotcha in there that's going to make it especially difficult? Other than having to pull the transmission and replacing the rear main seal, that is.
Additionally, all 4 conrod bearings were showing extreme wear, which is strange to me since the car's never been more than half a quart low in the past year. Everything was checked to be in spec with plastigauge, assembly lube was used during assembly, and the car was turned over long enough before starting that the oil channels should have been flowing fine. The oil was drained and refilled after a few hundred miles of running. And the wear pattern is what I would consider deeply strange:
1 on the left, what's left of 4 on the right
It doesn't appear to be the result of contaminated oil, but like the top of the bearing was ablated away by the impact at the top of the stroke, no foreign material required. Here's a close-up of #2:
What in the world is going on here? Did I install these in a new and spectacularly wrong way? Or were they just garbage bearings to start with?
The main crank bearings, FWIW, still look pristine, and the cam and turbo are both undamaged.
