Mickyroo
Hi there Iv been having similar issues on my 2004 golf 1.9tdi does anyone know where relay j329 is on mine as that relay board on my car has just one 460 and it's in slot on the right also can these be tested?
Don't know if i'll get a response given how old this thread is, but i need a little more information, please, regarding how to get the relays out of the harness, as i've already unintentionally broken untold numbers of clip retainers (many, but not all, on the module harness) and I still can't get the damn things loose/out! Which way do the things come out, towards the wires or away from the wires? I see lots of press-clips: are they the large black ones to the left and right of the "460"? If so, a flathead screwdriver fits on either side of each of these, so it's possible to exert pressure either in toward the relay or out away from the relay; i've tried both, and, as i said, I can't get the thing out, so i need to stop guessing: which is it, pressure in or pressure out? Or am i targeting the wrong clips?The Relay is on the lower left side of the Vehicle Electrical Control Module. It has "460" printed on the relay (its the "460" relay near my thumb in the picture below). The relay is in tight and has apposing snap tabs on either side to hold it to the module. I wedged two small screw drivers on either side to ensure the snap tabs would stay disengaged while I removed the relay.
Reverse the above process to close everything back up!
http://http://pics.tdiclub.com/data/503/thumbs/IMG_1091_3_.jpgFor under $13, this might be one of those relays to purchase and keep in the tool kit in the event they are ever needed on a long trip. Much like the relays for the Mk4s.
Thanks for the photos
