Cutypie
Thank you in advance for your help... So I was driving along, with no issues. The car did a little hiccup and miss, hmmm, but kept driving fine for 10+ miles. I exit near my home, about 2 miles later, complete shutdown, dash lights come on, and I coast for 3/4 mile then pull to the side. Try to restart, but sounds like no compression, with lots of engine shaking. I'm about to walk home, but I try it once more. It fires up and runs perfect to my house where I shut it off, and restarted a few times with no issues, and it's running perfect. Next day, I get in and make it about 600 feet and it dies. After a few attempts, it restarts, and I park it at the house. This is where I really start paying attention to what's happening...
I get out the VCDS and this is what I get:
VIN: 3VWDT71K16M6696969 License Plate: MS123456
Mileage: 293260km-182223mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 56 62 72
7D
VIN: 3VWDT71K16M6696969 Mileage: 293260km-182223miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 1010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H01--- Serial number: VWZ7Z0E2501592
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 64C712F0A76CD5AB47-8030
1 Fault Found:
005633 - Relay for Supply Voltage Terminal 30 (J317)
P1601 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00000000
(no units): 0.0
(no units): 0.0
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 042 H HW: 02E 927 770 AE
Component: GSG DSG 070 0913
Revision: 04507000 Serial number: 00000506070409
Coding: 0000020
VCID: 183F76002BA4C14B1B-804C
1 Fault Found:
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 255
Reset counter: 40
Mileage: 293265 km
Time Indication: 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0021122
VCID: 408FFE6013B4A98B83-8014
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 BA
Component: ClimatronicPQ35 066 0606
Shop #: WSC 00000 000 00000
VCID: 67DD05FC565ABEB362-8032
1 Fault Found:
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000140599
Coding: 14018E234004180000140000001400000028770B5C
Shop #: WSC 25649 444 00462
VCID: 2B55B9CC8A325AD346-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0402
Coding: 00065493
Shop #: WSC 25649
2 Faults Found:
01501 - Bulb for Blinkers; Rear Left (M6)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 76
Mileage: 292177 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.75 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 10
Reset counter: 101
Mileage: 293263 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.10 V
ON
ON
OFF
OFF
OFF
Address 0F: Digital Radio Labels: None
Part No SW: 1K5 035 553 K HW: 1K5 035 553 K
Component: SDAR XM H04 0160
Revision: 00000000 Serial number: VWZ4Z7G0090197
VCID: 3169ABA4A81E30037C-8064
2 Faults Found:
00532 - Supply Voltage B+
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 68
Mileage: 290817 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:58
Freeze Frame:
Voltage: 16.60 V
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 138
Mileage: 284249 km
Time Indication: 0
Date: 2000.00.00
Time: 11:11:58
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD03HNRR
Coding: 0012627
VCID: 2E53B0D8B9202FFB61-807A
Subsystem 1 - Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Subsystem 2 - Serial number: 6332MSME0A663717B
Subsystem 3 - Serial number: 6342MSME0B7544014
Subsystem 4 - Serial number: 6351HSME08150B3FA
Subsystem 5 - Serial number: 6361HSME08175F66G
Subsystem 6 - Serial number: 63727SME0729641D2
Subsystem 7 - Serial number: 63827SME071F1760+
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
Component: J0527 034 0070
Coding: 0012021
VCID: 7AFB4C8835E8335B8D-802E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 972 D
Component: KOMBIINSTRUMENT 3HL 1212
Coding: 0023203
VCID: 2D51B7D4B42654E358-8078
1 Fault Found:
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001057078D42
Coding: 3F7F0B600F1002
VCID: 2A5BBCC885C843DBBD-807E
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 101
Mileage: 293263 km
Time Indication: 0
Date: 2000.00.00
Time: 03:55:14
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1293324T07S101
Coding: 0000003
VCID: 39799384706EF843C4-806C
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 1212
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
Component: Sitzverstellung 0701
Revision: 00003000 Serial number: 00000000000000
VCID: 2C57BAD08F3C5DEB4F-8078
1 Fault Found:
02328 - Position Sensor for Rear Seat Height Adjustment (G439)
011 - Open Circuit - Intermittent
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 366398B84170173B29-8062
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 326BA4A8AD180B1B05-8066
1 Fault Found:
Freeze Frame:
Mileage: 3240 km
Temperature: 34.0°C
Voltage: 14.20 V
Voltage: 13.90 V
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 13900E880106281B0904050FB0080F0480A540
VCID: 020B34685D387B9BD5-8056
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
5 Faults Found:
00930 - Locking Module for Central Locking; Rear Left (F222)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01110011
Fault Priority: 4
Fault Frequency: 6
Reset counter: 37
Mileage: 0 km
Time Indication: 0
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 4
Fault Frequency: 2
Reset counter: 68
Mileage: 290817 km
Time Indication: 0
Date: 2000.00.00
Time: 00:01:13
00931 - Locking Module for Central Locking; Rear Right (F223)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 179
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Status: 00110001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 68
Mileage: 290817 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:15
01038 - Central Locking Thermal Protection
000 - - - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 68
Mileage: 290817 km
Time Indication: 0
Date: 2000.00.00
Time: 00:01:13
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 377D95BC467AEE3332-8062
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio ZSW 016 0017
Revision: 00016000 Serial number: VWZ5Z7E6011286
Coding: 0040400
VCID: 204F5EE0F3F4898BE3-8074
1 Fault Found:
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 68
Mileage: 290817 km
Time Indication: 0
Date: 2000.00.00
Time: 00:03:37
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
End-------------------------(Elapsed Time: 02:14)--------------------------
I check the battery, grounds, shake the looms, checked the fuses for looseness, etc. Go for the start, and the car starts and runs fine. I take it for a test ride and it runs great for around 16 miles, then I hear a relay clicking and the engine intermittently loses power, then continues to run. I head for home, two dead stops later and I'm safely parked at my house. I didn't notice before, but now I see the display is flashing PRNDS, and the check engine and glow plug light are not lighted. I do more research... Hook up to VCDS and now I'm getting this, and there is more to follow...
7D
VIN: 3VWDT71K16M6696969 Mileage: 293290km-182241miles
01-Engine -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
1C-Position Sensing -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine
Cannot be reached
Coding: 0000020
VCID: 183F76002BA4C14999-804C
1 Fault Found:
P1850 - 000 - Missing Message from ECU - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Reset counter: 40
Mileage: 293293 km
Time Indication: 0
Revision: 00T12001
Coding: 0021122
VCID: 408FFE6013B4A98901-8014
1 Fault Found:
VCID: 67DD05FC565ABEB1E0-8032
4 Faults Found:
00457 - Central Electronics Control Module / BCM (J519)
013 - Check DTC Memory
00819 - High Pressure Sensor (G65)
006 - Short to Plus
01316 - ABS Control Module
VCID: 2B55B9CC8A325AD1C4-807E
Coding: 00065493
Shop #: WSC 25649
10 Faults Found:
01516 - Terminal 30; Left
Freeze Frame:
Fault Status: 00101011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
02403 - Terminal 15 for Interior
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.70 V
ON
ON
OFF
OFF
OFF
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.30 V
ON
ON
OFF
OFF
OFF
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.30 V
ON
ON
OFF
OFF
OFF
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.65 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 63
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
02389 - Release Signal Transmission; Position P/N
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.80 V
ON
ON
OFF
OFF
OFF
00927 - Terminal 30 (Right)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
VCID: 3169ABA4A81E3001FE-8064
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 06:52:20
Freeze Frame:
Voltage: 15.50 V
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 63
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:46:00
Coding: 0012627
VCID: 2E53B0D8B9202FF9E3-807A
1 Fault Found:
02511 - Control Module for Seat Occupied Recognition (J706)
004 - No Signal/Communication - Intermittent - MIL ON
Coding: 0012021
VCID: 7AFB4C8835E833590F-802E
1 Fault Found:
00002 - Transmission Control Unit
Coding: 0023203
VCID: 2D51B7D4B42654E1DA-8078
1 Fault Found:
VCID: 2A5BBCC885C843D93F-807E
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 31
Reset counter: 63
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 11:27:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:31
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:31
01335 - Drivers Seat/Mirror Position Control Module (J543)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:35
Coding: 0000003
VCID: 39799384706EF84146-806C
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:42
VCID: 2C57BAD08F3C5DE9CD-8078
Coding: 0001269
VCID: 366398B841701739AB-8062
VCID: 326BA4A8AD180B1987-8066
2 Faults Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Mileage: 3280 km
Temperature: 16.0°C
Voltage: 13.30 V
Voltage: 13.10 V
00778 - Steering Angle Sensor (G85)
000 - -
Freeze Frame:
VCID: 020B34685D387B9957-8056
4 Faults Found:
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 05:44:53
Freeze Frame:
Fault Status: 01101101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 63
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 11:12:28
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:33
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:33
Coding: 0001269
VCID: 377D95BC467AEE31B0-8062
Address 56: Radio Labels: 1K0-035-1xx-56.clb
Coding: 0040400
VCID: 204F5EE0F3F4898961-8074
Coding: 0000144
Coding: 0000144
End-------------------------(Elapsed Time: 02:17)--------------------------
The hunt continues. I unwrap and inspect the wire looms under the airbox and battery, remove the ECM, unwrap and inspect the wire looms from the firewall to the ECM, check for voltage to the ECM the best I could with the information I had - (Pins 3, 5, 21 and 62, plus the grounds on the ECM) - all showed good voltage on positive and continuity on the grounds. I remove every relay under the drivers side and test them, including the 458 in the engine compartment. All seem to be good. Check power to every fuse, all good. Try to start the car. If I go for a quick start, like don't wait for the glow plug light, it fires for a second then dies immediately. I exercise the ignition without starting many times. Sometimes the check engine and glow plug illuminate, sometimes they don't. At some point during exercising the ignition, the PRNDS stopped flashing. I ran VCDS on the engine module and I was able to pull this (below), then 45 seconds later PRNDS started flashing, then back to a brick.
Control Module Part Number:
Component and/or Version:
Software Coding:
Work Shop Code:
VCID: 55A13F34AC363C2142-FFFE
1 Fault Found:
Readiness: N/A
I continue exercising the ignition so I can hear what's going on. When I energize it and leave it on, the cooling fan turns on and runs fast, but it still won't start when cranked. I disconnect the cooling fan so I can hear better. Sometimes when I turn the ignition on without cranking, I get the check engine and glow plug light, sometimes I don't. I keep exercising with the ignition, which is also exercising the relays. At some point the PRNDS light stopped flashing and I was able to start the car. It ran for like 40 seconds (perfectly), then the glow plug light flashed, I heard a relay click, and the engine abruptly shut off. I kept this up and was able to keep the engine running for longer and longer each time. It seemed to be running perfect and for several minutes, so I cleared the codes in VCDS and all of the dash lights were normal. I drove the car down my driveway and re-parked it, and it ran perfectly. I reconnect the cooling fan and let the car idle, with an occasional slight push of the pedal. Everything is good. After like 10 minutes I see the glow plug light flash rapidly, hear a relay clicking, and the engine stutters, but continues to run. A couple more minutes of running, the glow plug flashes, relay is clicking, and she's gone again, now back to flashing PRNDS and cranking, but no start condition. I feel like I hear a relay on the passenger side clicking when the glow plug relay is clicking, but I'm not positive. I have a lot of the car torn apart at this point and I'm hoping someone will have some experience with this issue they can share before I have to tear the passenger side apart too. Here is the last VCDS while it was running. I'm feeling like there is an issue with Terminal 30 that I haven't been able to locate. The wires in the looms look to be in good condition, and after inspecting them closely, I did not find any severe chafing on them. Thanks again for your help and experience.
7D
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
Coding: 0050078
VCID: 64C712F0A76CD5A9C5-8030
VINID: 0E69D490705B0467461892400873865042
Readiness: 0 0 0 0 1
Coding: 0000020
Revision: 00T12001
Coding: 0021122
9 Faults Found:
01309 - Power Steering Control Module (J500)
01312 - Powertrain Data Bus
014 - Defective - Intermittent
00474 - Control Module for Immobilizer
01299 - Diagnostic Interface for Data Bus (J533)
01317 - Control Module in Instrument Cluster (J285)
000 - -
3 Faults Found:
006 - Short to Plus - Intermittent
Coding: 00065493
Shop #: WSC 25649
1 Fault Found:
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.25 V
ON
ON
OFF
OFF
OFF
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 06:52:20
Freeze Frame:
Voltage: 15.50 V
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 63
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:46:00
Coding: 0012627
3 Faults Found:
Coding: 0012021
Coding: 0023203
5 Faults Found:
01315 - Transmission Control Module
Coding: 0000003
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:42
1 Fault Found:
02325 - Switch for Front Seat Height Adjustment (E451)
003 - Mechanical Failure - Intermittent
Coding: 0001269
4 Faults Found:
Freeze Frame:
Mileage: 8560 km
Temperature: 14.0°C
Voltage: 13.40 V
Voltage: 13.30 V
Freeze Frame:
Mileage: 3280 km
Temperature: 12.0°C
Voltage: 10.30 V
Voltage: 10.10 V
00625 - Vehicle Speed Signal
Freeze Frame:
Mileage: 3280 km
Temperature: 14.0°C
Voltage: 12.50 V
Voltage: 12.20 V
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Mileage: 3280 km
Temperature: 16.0°C
Voltage: 8.60 V
Voltage: 8.50 V
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 05:44:53
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:33
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:33
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 03:09:12
Coding: 0001269
Coding: 0040400
Coding: 0000144
Coding: 0000144
End-------------------------(Elapsed Time: 02:05)--------------------------
7D
Coding: 0050078
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00000000
(no units): 0.0
(no units): 0.0
Coding: 0000020
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 293265 km
Time Indication: 0
Revision: 00T12001
Coding: 0021122
1 Fault Found:
1 Fault Found:
Coding: 00065493
Shop #: WSC 25649
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 76
Mileage: 292177 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.75 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 101
Mileage: 293263 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.10 V
ON
ON
OFF
OFF
OFF
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 68
Mileage: 290817 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:58
Freeze Frame:
Voltage: 16.60 V
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 138
Mileage: 284249 km
Time Indication: 0
Date: 2000.00.00
Time: 11:11:58
Coding: 0012627
Coding: 0012021
Coding: 0023203
1 Fault Found:
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 101
Mileage: 293263 km
Time Indication: 0
Date: 2000.00.00
Time: 03:55:14
Coding: 0000003
1 Fault Found:
Coding: 0001269
1 Fault Found:
1 Fault Found:
Freeze Frame:
Mileage: 3240 km
Temperature: 34.0°C
Voltage: 14.20 V
Voltage: 13.90 V
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 6
Reset counter: 37
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 68
Mileage: 290817 km
Time Indication: 0
Date: 2000.00.00
Time: 00:01:13
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 179
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 68
Mileage: 290817 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 68
Mileage: 290817 km
Time Indication: 0
Date: 2000.00.00
Time: 00:01:13
Coding: 0001269
Coding: 0040400
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 68
Mileage: 290817 km
Time Indication: 0
Date: 2000.00.00
Time: 00:03:37
Coding: 0000144
Coding: 0000144
7D
Address 01: Engine
Cannot be reached
Coding: 0000020
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 293293 km
Time Indication: 0
Revision: 00T12001
Coding: 0021122
1 Fault Found:
4 Faults Found:
006 - Short to Plus
Coding: 00065493
Shop #: WSC 25649
10 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.70 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.30 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.30 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.65 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 63
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.80 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 06:52:20
Freeze Frame:
Voltage: 15.50 V
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 63
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:46:00
Coding: 0012627
1 Fault Found:
Coding: 0012021
1 Fault Found:
Coding: 0023203
1 Fault Found:
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 31
Reset counter: 63
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 11:27:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:31
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:31
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:35
Coding: 0000003
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:42
Coding: 0001269
2 Faults Found:
Freeze Frame:
Mileage: 3280 km
Temperature: 16.0°C
Voltage: 13.30 V
Voltage: 13.10 V
000 - -
Freeze Frame:
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 05:44:53
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 63
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 11:12:28
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:33
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:33
Coding: 0001269
Coding: 0040400
Coding: 0000144
Coding: 0000144
Software Coding:
Work Shop Code:
1 Fault Found:
Readiness: N/A
7D
Coding: 0050078
Coding: 0000020
Revision: 00T12001
Coding: 0021122
9 Faults Found:
000 - -
3 Faults Found:
Coding: 00065493
Shop #: WSC 25649
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.25 V
ON
ON
OFF
OFF
OFF
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 06:52:20
Freeze Frame:
Voltage: 15.50 V
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 63
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:46:00
Coding: 0012627
3 Faults Found:
Coding: 0012021
Coding: 0023203
5 Faults Found:
Coding: 0000003
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:42
1 Fault Found:
Coding: 0001269
4 Faults Found:
Freeze Frame:
Mileage: 8560 km
Temperature: 14.0°C
Voltage: 13.40 V
Voltage: 13.30 V
Freeze Frame:
Mileage: 3280 km
Temperature: 12.0°C
Voltage: 10.30 V
Voltage: 10.10 V
Freeze Frame:
Mileage: 3280 km
Temperature: 14.0°C
Voltage: 12.50 V
Voltage: 12.20 V
Freeze Frame:
Mileage: 3280 km
Temperature: 16.0°C
Voltage: 8.60 V
Voltage: 8.50 V
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 05:44:53
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:33
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:33
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 293293 km
Time Indication: 0
Date: 2000.00.00
Time: 03:09:12
Coding: 0001269
Coding: 0040400
Coding: 0000144
Coding: 0000144
