Car sat for 6 months while I waited to replace the alternator/AC bracket.
Replaced the bracket, started the engine, it started right up, then died, I tried to restart - it would not start.
I checked all the fuses, they were all OK
I pulled the codes and looking for advice from the TDIClub Gurus.
Friday,13,May,2022,14:28:09:06266
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.3.1.4 (x64) HEX-NET2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: 3VWST71K66M785555 License Plate:
Chassis Type: 1K (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: 3VWST71K66M785555 Mileage: 497060km-308858miles
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0021122
Shop #: WSC 00066 000 00000
VCID: 71B4BF74CDA89D23301-8024
3 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication - Intermittent
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 EC
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 6984D714E57865E3781-803C
2 Faults Found:
00532 - Supply Voltage B+
00229 - Refrigerant Pressure
001 - Upper Limit Exceeded
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000276320
Coding: 14018E234004150000140000001400000008730B5C
Shop #: WSC 06434 444 57239
VCID: 2A06681820FEAEFBB1B-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 06434
2 Faults Found:
01117 - Generator Terminal DF Load Signal
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 6
Reset counter: 157
Mileage: 497065 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.00 V
ON
ON
OFF
OFF
OFF
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 5
Reset counter: 157
Mileage: 497065 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 9.30 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 39 AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD04AN9%
Coding: 0013113
VCID: 39244754D5581563C81-806C
Subsystem 1 - Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Subsystem 2 - Serial number: 6332MSME0C6E6A12M
Subsystem 3 - Serial number: 6342MSME0E47585CR
Subsystem 4 - Serial number: 6351HSME09235D6BG
Subsystem 5 - Serial number: 6361HSME092E07000
Subsystem 6 - Serial number: 63727SME087E5E18H
Subsystem 7 - Serial number: 63827SME08795C0DF
1 Fault Found:
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0000021
VCID: 78A28250AED2CC6BF7F-802C
No fault code found.
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 953 D
Component: KOMBIINSTRUMENT 3HL 4312
Coding: 0023203
Shop #: WSC 06434 444 52592
VCID: 2C0A6E002A0AB0CB437-8078
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001061020173
Coding: 3D3F0B60071002
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 137803281B09058F880F048051A0
Shop #: WSC 08213 444 45725
VCID: 74BAB660B2BAA80BDB7-8020
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
Address 56: Radio Labels: 1K0-035-1xx-56.clb
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio DE2 011 0015
Revision: 00011000 Serial number: VWZ4Z7F2106098
Coding: 0040400
VCID: 20128A3056C264ABEFF-8074
1 Fault Found:
01305 - Databus for Infotainment
014 - Defective - Intermittent
End----------(Elapsed Time: 04:27, VBatt start/end: 12.8V/12.3V)-----------
www.Ross-Tech.com
75 76
Revision: 00H13001
Coding: 0021122
3 Faults Found:
2 Faults Found:
Coding: 00063445
Shop #: WSC 06434
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 157
Mileage: 497065 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.00 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 157
Mileage: 497065 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 9.30 V
ON
ON
OFF
OFF
OFF
Coding: 0013113
1 Fault Found:
Coding: 0000021
Coding: 0023203
Component: KSG 0401
1 Fault Found:
Coding: 0040400
1 Fault Found:
