2006 jetta passenger side window
vova
Veteran
Los Gatos CA
2006 jetta tdi
The passenger side window in my jetta periodically stops working. Will open half way and not go up for a few days and then will start working again.
Any suggestions where to start? Switch, broken wire, motor?
sptsailing
Safety Harbor, FL
2006 Jetta Manual, stock with Panzer Plate & Franko6 modified EGR cooler & CAM
Oilhammer's observations are most likely the case. I have had to replace several window switches, which solved some of the problems. These are relatively easy to testl Fortunately, years ago I was able to obtain a replacement driver door wire harness replacement, which was definitely needed. I have not experienced any bad window motors yet.
