So, everything started failing at once a month or two ago.. I'm down to a hand full of issues now.
I recently had my clutch + flywheel replaced due to some slippage, clacking from transmission, and clutch pedal pressure issues. All of the symptoms disappeared after the clutch job except for the pedal pressure issues.
* Clutch operates normally until it warms up, then one of the following issues start:
- Slow decrease in clutch 'catch' point. (almost to the floor sometimes)
- random clutch 'stick' clutch sticks down, pop it back up with my foot things return to normal.
given the latter symptom, I'm thinking the clutch master cylinder under the dash is acting up. Thoughts?
I've actually never changed the hydraulic fluid (2-3 years). Think changing it would be a good start? (or just make things worse?)
Is there a bleeder valve on the clutch master cylinder under the dash? (know there is one on the slave under the air box)
