2006 Jetta BRM Turbo Actuator Stop Adjustment
TDI Greg
Washington Court House, Ohio
2002 Jetta ALH
Hey guys. I installed a new turbo center section and actuator on my stock turbo and I'm wondering how to set up the actuator. All the info I could come up with was for ALH or for putting an ALH style actuator on a BEW/BRM. TIA
jetta 97
Dallas (McKinney) ,TX ,USA
2 X Jatta MK5 2006
Same as ALH , with vacuum pump about 4 to start and 18 to end. But on BRM most important is Stop Bolt , this has to be dome with VCDS , in basic settings 011. The difference between open and close can not be more then 150 , 100 in ideal. I usualy tell everyone use Zip Tight mode fist , fine best position then apply vacuum to full extend actuator then tight bolt till it stop.
Google BRM Zip tight mode and you will see what I am talking about .
pedroYUL
MI, USA
2015 Passat CVCA; 2015 GSW CRUA; 2004 wagon BEW(brother)
Yes, what Jetta says. The only difference is in the BRM the actuator extends the rod with vac, whereas in the ALH and BEW the actuator shortens the rod with vac
