2006 Jetta BRM - P0122 Throttle Issues
KenGee
Alberta
2006 Jetta TDI MkV BRM
I recently purchased a 2006 TDI Jetta, Mk5 with the BRM engine, 5 speed manual.
I have the pesky P0122 code, "Throttle Position Sensor/Switch A Circuit Low Input". I replaced the Throttle Position Sensor (TPS) and still get the same code. So I disconnected the battery for 10 minutes thinking it might reset, no dice.
So I cleaned the grounds under the airbox (another forum member stated this fixed his/her issue), no dice. Then I disconnected the TPS and tested the voltage on the plug, and everything came back as normal (as per 2 other forum posts):
Pin 1 to ground - 5v
Pin 2 to ground - 5v
Pin 1 to 5 - 5v
Pin 2 to 3 - 5v
I would ignore it if it was just a code, but unfortunately the car is acting up. Randomly when driving, the accelerator stops working. Whether I am maintaining speed, or speeding up, the vehicle stops accelerating and I start coasting and slowing down. The tach just starts slowly dropping, as though I had just thrown the car into neutral and continues to idle and doesn't shut down. In order to get moving again, I have to shift into neutral, then back into gear. 75% of the time it works, the other 25% I have to do it multiple times to get the car/throttle working again.
The weird thing is that cruise control works great, I can drive for days without an issue. When it happened today, I was close to my cruise control speed setpoint, so I pulled the cruise lever to resume, and the car began accelerating to my desired speed then maintained it as if there were no problems. So I don't believe this is anything other than a throttle issue (not a fuel issue or otherwise).
Is this something I will need a VAG com to reset or calibrate the TPS?
Is there a way to test the new pedal tps vs the old pedal tps to confirm that the new one is working correctly?
I know VAG com is the way to go, and I am in the process of ordering one. However, I need this car running asap and can't afford to wait for delivery, then try and learn how to properly use the VAG.
Any help would be greatly appreciated!
Carlos_TJ
Tijuana Mexico
2009 Bora (BXE PD)
Seems to me you are using a generic obdii scanner. The code it is reporting to you might be something totally different if scanned using vag com.
Your BRM does not have a tps. In fact it is throttle by wire meaning the pedal is a potentiometer connected to the computer. The part most likely you are referring as the tps might be in fact the Anti shudder valve ?
Your symptoms look like typical accelerator pedal fail. When the problem happens do the rpms go up to ~1200 rpms?
These cars have two sets of code tables. The gov mandatory obd11 which are emissions relates and the way more extensive vag propiertary which are a very powerful diagnistic tool.
Thats the reason using generic scanners is a hit or miss...
KenGee
Alberta
Thanks for the reply Carlos. You're absolutely right, I am using an OBD2 scanner, waiting for my VAG com to come in.
You're also right about the TPS, I am incorrectly calling the sensor in the pedal the TPS. I have replaced the pedal and am still having issues. The ASV is disconnected, along with the EGR, which might be causing some issues?
The RPMs don't go up at all, it's as though I just threw the car into neutral. I guess I'll just have to wait for the VAG to come in. Thanks again for your corrections and reply!
Carlos_TJ
Tijuana Mexico
2009 Bora (BXE PD)
Hey Ken
Yes either wait for your cable to arrive or find someone with one because there should be codes stores that will steer you in the right direction.
Once you can scan the car be sure to post the scan log in this thread so we can take a look.
KenGee
Alberta
Hey Ken
I'm not sure if there's a better way to post this log? If so I'll edit!
Thursday,27,June,2019,08:32:28:60229
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.0.6 (x64) HEX-V2 CB: 0.4505.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 36 42 44 46 52 56 62 72 7D
VIN: Mileage: 281570km-174959miles
00-Steering Angle Sensor -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
1C-Position Sensing -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H01--- Serial number: VWZ7Z0E3216513
Coding: 0050071
Shop #: WSC 00066 000 00000
VCID: 6393AF99D75B0C4FB77-8036
4 Faults Found:
001031 - EGR Sensor 2
P0407 - 000 - Signal too Low
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 281430 km
Time Indication: 0
Date: 2000.00.00
Time: 17:31:15
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Lambda: -25.0 %
Mass Air / Rev.: 850.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Bin. Bits: 00000000
008214 - Intake Manifold Flap Position Sensor (Bank 1)
P2016 - 000 - Short to Ground
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 281430 km
Time Indication: 0
Date: 2000.00.00
Time: 17:31:15
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Duty Cycle: 95.1 %
Bin. Bits: 00000000
000833 - Camshaft Position Sensor (G40)
P0341 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 12
Reset counter: 255
Mileage: 281466 km
Time Indication: 0
Date: 2000.00.00
Time: 17:54:09
Freeze Frame:
RPM: 2562 /min
Speed: 118.0 km/h
Load: 40.8 %
Voltage: 14.36 V
Bin. Bits: 00101000
Idle Stabilization: 0.0°KW
(no units): 48.0
001602 - Sensor Reference Voltage A
P0642 - 000 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 281499 km
Time Indication: 0
Date: 2000.00.00
Time: 18:12:57
Freeze Frame:
RPM: 798 /min
Speed: 4.0 km/h
Bin. Bits: 00100000
Bin. Bits: 00000000
Bin. Bits: 00100000
Bin. Bits: 00100000
Bin. Bits: 00000000
Readiness: 1 2 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0021122
VCID: 71BFD5D11DA7AEDF35B-8024
No fault code found.
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 DQ
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 76B5E6CD74C989E7E09-8022
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000268411
Coding: 10018E234004180000140000001400000028770B5C
Shop #: WSC 91518 999 84490
VCID: 2B0307B9FF0B840F4F7-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 91518
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 3C AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD0493AM
Coding: 0013123
VCID: 392F2DF10557269FCDB-806C
Subsystem 1 - Serial number: 6332MSME0D4C6C7F/
Subsystem 2 - Serial number: 6342MSME0D3F0A15J
Subsystem 3 - Serial number: 6351HSME09140E511
Subsystem 4 - Serial number: 6361HSME091D4854C
Subsystem 5 - Serial number: 63727SME087956689
Subsystem 6 - Serial number: 63827SME087A0533/
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
Component: J0527 034 0070
Coding: 0002021
VCID: 7AADF2FD40D1ED87841-802E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 007 0050
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 872 M
Component: KOMBIINSTRUMENT 3HL 4312
Coding: 0023307
VCID: 353721C1294FC2FF293-8060
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105C281724
Coding: 3D7F0B400F1002
VCID: 2A0D02BDF0F19D07B41-807E
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1293324T1X6L01
Coding: 0000003
1 Fault Found:
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 4312
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
Component: Sitzverstellung 0701
Revision: 00003000 Serial number: 00000000000000
VCID: 2C0104A5FA05833746D-8078
4 Faults Found:
02344 - Seat Position Memory Store Switch (E447)
003 - Mechanical Failure
02332 - Position Sensor for Backrest Adjustment (G440)
011 - Open Circuit - Intermittent
01916 - Lumbar Support Fore / Aft Adjustment Sensor (G375)
01915 - Lumbar Support Height Adjustment Sensor (G374)
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 363526CD3449C9E7209-8062
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 33331FD9273BDCCF077-8066
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 13900E880106283F6D04058FB0080F0480A540
VCID: 025D8A1D2801A547DC1-8056
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
00668 - Supply Voltage Terminal 30
Freeze Frame:
Fault Status: 00110010
Fault Priority: 4
Fault Frequency: 2
Reset counter: 172
Mileage: 0 km
Time Indication: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 372B2BC9334330EF3BF-8062
3 Faults Found:
00933 - Electric Window Motor; Passenger Side (V148)
012 - Electrical Fault in Circuit
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
00944 - Heated Exterior Mirror; Passenger Side (Z5)
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 D HW: 1K0 035 180 D
Component: Radio ZSW 016 0017
Revision: 00016000 Serial number: VWZ5Z7F6031017
Coding: 0040400
VCID: 211FE5918DC75E5FE5B-8074
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Mileage: 279847 km
Time Indication: 0
Date: 2000.00.00
Time: 03:52:46
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 313F15D1DD27EEDF75B-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 323D1ADDD821D5C70C1-8066
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D0709A1C11F8A3F513-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End----------(Elapsed Time: 01:12, VBatt start/end: 12.3V/12.4V)-----------
sptsailing
Safety Harbor, FL
2006 Jetta Manual, stock with Panzer Plate & Franko6 modified EGR cooler & CAM
Wow. Those are a lot of malfunctions. Please review this forum for posts about grounds, as your collection of malfunctions looks to me like it is caused by bad grounds somewhere. Grounds going bad in these cars is a very common cause of problems.
bobthefarmer
Indianapolis
2006.5 Jetta Mk 5 192K miles; 2012 Car of the Year, Passat Tdi SE+Nav in blue nightgown, shod in 18 inch heels
It also could be battery problems. I've had a HOST of malfunction code 0010 before. They are all about electrical gremlins. Then there is a pesky relay that came up on my car recently. I forgot the number, but I'll get back with you.
KenGee
Alberta
Hi Bob, any info regarding that relay? I'm terrible with any electrical issues, so any help would be much appreciated.
I noticed that some of the bigger fuses (I believe? They were labelled with numbers like 80) near the front of the battery have a lot of corrosion or buildup on them...cleaning them might be a good starting point.
Also, for anybody else who can chime in, is this something a Volkswagen dealership could find/take care of with relative ease? This is an older car, so sinking $3k into it is not my ideal path. My throttle issues, along with some of the other faults seem to be related to low voltage/current issues. I barely understand electrical systems, let alone troubleshooting and finding problematic relays/grounds, so digging into this too deeply is not likely something I can do quickly/by myself.
Thanks!
mextdi
Saint Paul, Minnesota
2006 Jetta TDI 1.9, 2012 Passat TDI SE DSG, Previous 2014 Beetle TDi, 2012 Golf TDi DSG
Some of the faults you are seeing come up when you disconnect the battery and then just plug in the Vagcom and read for codes. You are on the right track reading your codes with the Vagcom and testing accordingly. As far as corrosion and wire damage and such, a lot of people on here have found damage in the area that is under the battery where the electrical wires are all in a plastic channel, look around that area for any frayed or disconnected wires. Also, sometimes when you swap parts out and you get the same error message either you need to clear codes and retest or the new part is faulty or the error is due to an electrical gremlin nearby. If you do have corrosion and such in your fuse and relay areas, clean those out and make sure you dry it all well before running the car or you can cause worse shorts, ha. As far as going to the dealership, not every dealership has a TDI or MKV guru. Sure, MKVs have lots of common faults, including leaky sunroofs.... but I would look for an electrical systems guru who can pinpoint errors quickly and easily and won't charge dealership fees. Remember that dealerships don't always have well trained mechanics because they get fed up with low pay and instead work for independent shops. Ask around and someone should know someone in your neck of the woods who can help you out. And lastly, sometimes you do have to reprogram or recalibrate the throttle when you replace it, especially if part numbers are superseded or different. To do that, you can probably find it on the Vagcom forum, lots of DIY info there.
Lots of luck!!!!!
AnericanProud
Iowa
2005.5 VW Jetta
Have you figured out what was the problem? Mine is acting the same way yours is and cruise is how I was getting down the highway. Very frustrating. Any help would be greatly appreciated before I go and drop tons of money into it and not have anything help. Thanks again!
KenGee
Alberta
Unfortunately I never was able to 100% positively identify what was causing the issue. However, after cleaning all the grounds, disconnecting then reconnecting the ECM, and cleaning the bar fuses on the front of the battery the problem went away.
Then the clutch went and the shop that fixed it likely didn't support the engine, so the car started spewing oil when I was 8 hours from home so I cut my losses and scrapped it - a real shame.
The car could never make it the 134km round trip to work without acting up, but after doing all of those things, plus replacing the pedal and clearing the codes with the VAG com (and any other stuff I posted about here), my issues never reappeared for the 1000km before the clutch went.
Best of luck. I want another VW soon...if you haven't, get yourself the vag com cable and save yourself some money and many headaches! Cheers!
AnericanProud
Iowa
2005.5 VW Jetta
Thanks for answering me. I have thought about buying the VAG com but with roughly 371,000 km I don't want to be wasting my money buying it to see the car have to be scraped in another 1000 km. I've had the car for the last 80,000 km and problems after problems have been happening in the last 15,000 km or so. I don't know how much longer this car gonna last is my only worry. If you think the VAG com is a good investment I might have to get it. Just looking to see if it helped you out as much as the price is.
KenGee
Alberta
I know where you're coming from for sure! The nice thing for me was that I sold the cable when the car was scrapped, so it only cost me $75CAD..less than half an hour of labour. I have no affiliation with the company, but can definitely say that it was the single best tool or part I've ever bought for any of my vehicles!
Sent from my SM-G965W using Tapatalk
