Salmonbum
OK, I looked under the hood a bit better at the fan setup. Looks like there is one shround that both fans are connected to. A torx (or triple square?) screw holds it in place at each corner. I take it the entire shroud needs to come out to replace the fan?
I tried tapping on the smaller fan motor to see if it would act like it wanted to fire......nothing. I see IDparts has the fan for $130 or so. Anybody use this one?
Thanks everyone for the help. If this doesn't help my problem (air getting warmer when stopped) then I will then extract and recharge refridgerant and possibly the hi/low pressure switch.
