2006 Jetta 1.9L PD TDI (BRM) code P0299
fanw01
Omaha, NE
2012 Passat SE tdi
Hi all, I am new to the site and a new TDI owner. I purchased my TDI in Oct 2011 and now having a problem.
I have a 2006 Jetta 1.9L PD TDI (BRM) with 92,000 miles; I am having the following problem. I purchased the car with 87,000 miles and now have 92,000 miles, while driving the check engine light came on and the car went into limp mode. When I checked the codes with my OB2 scanner the code retrieved was “P0299 under Boost condition”. I took the car to the dealer and they wanted to install a new turbo for the car. I did not allow them to install the turbo at a cost of $2900.00. I cleared the code and got the car out of limp mode. This problem is happening about twice a month. When I view the freeze frame data on my scanner, the condition is happening at or around 45-60mph. If it happens on the highway the cruise control will shut off also which I would expect. After searching on this site I am seeing that this is a common problem with the TDI’s. Where should I start my troubleshooting? I am pretty handy working on cars and have tools needed or will buy the tools needed.
I think the turbo actuator is the problem. After checking vacuum at the actuator, the actuator will not hold vacuum. Does anyone know if there are Turbo repair kits for the 2006 TDI (BRM)?
fanw01
Omaha, NE
2012 Passat SE tdi
Thanks for the response. I will check the N75 valve again. This is a very frustrating problem.
Ol'Rattler
PNA
2006 BRM Jetta
Seems like many dealers consider replacing the turbo is a part of the troubleshooting process.
Service adviser: Sir, to continue troubleshooting your car, we have to replace the turbo because all we know how to do is to keep throwing parts at the problem until either we fix the problem or we destroy your car. Oh, and Sir, you will need to get a 2nd mortgage on your house to pay for our incompetence..........
DanG144
Chapin, South Carolina, USA
2005 A4 Jetta 5spd
If it is the vacuum motor actuator on the turbo itself, I know of no aftermarket source for the BRM. I did think I saw one for the Common Rail engines, but I don't know if it will work for the BRM. There are superficial simularities between the BRM and CJAA.
Looking for a used one may be your best bet.
fanw01
Omaha, NE
2012 Passat SE tdi
After lots of research I found a company online called KermaTdi that sells a supposed replacement for the smart actuator.
http://www.kermatdi.com/servlet/-strse-213/VNT-Actuator/Detail http://www.kermatdi.com/servlet/-strse-213/VNT-Actuator/Detail
Has anyone tried this yet? How much work is it?
This sounds interesting. I really cannot believe this situation with the trubo actuator on the 2006 VW BRM 1.9L PD. A small part failure and you have to buy a complete turbo. Crazy!!! I am still looking for an alternative to buying a complete turbo. There have to be some place to buy the actuator. There are places that sell rebuilt turbo's and vendors that sell turbo with the actuator for a lot less than the dealer is asking. This vendor sells new and rebuilt units. Have anyone used a turbo from this vendor?
http://www.carpartswarehouse.com/addtocart/2007_Volkswagen/Jetta/Turbocharger/40-30118.htmlhttp://www.carpartswarehouse.com/addtocart/2007_Volkswagen/Jetta/Turbocharger/40-30118.html
turbocharged798
Ellenville, NY
Those won't work as they are for the Mk4 chassis cars which uses vacuum to pull the rod. The MK5 uses vacuum to push the rod. Closest thing you are going to find is this:
http://idparts.com/catalog/product_info.php?products_id=2797
Its a CR actuator. Might be possible to make it fit on a BRM.
ecaddy
Illinois
2006 Jetta TDI
2006 Jetta Turbo actuator
I bet there are companies that can fix these things. If not, they may be an opportunity because I just dropped $1000 friday for a new turbo because of this stupid actuator.
ecaddy
Illinois
2006 Jetta TDI
The new turbo should arrive by Friday so that is what I will be doing this weekend. I will let you know if that fixes the problem. Going to be upset if it doesn't. The stealership I bought the car from was not a VW dealer so they put on a used turbo to fix the exact same problem in Febuary. There was only a 30 day warranty so now I'm stuck paying for everything.
If it does work I will try and take pictures because I have not been able to find a removal procedure yet on the 2006 brm engines.
fanw01
Omaha, NE
2012 Passat SE tdi
Did the new turbo fix your limp mode problem? I still have not fixed my turbo limp mode problem. Trying to hold out for an actuator in the near future, but it is not looking good. I may be in the same situation of buying a new turbo.
ecaddy
Illinois
2006 Jetta TDI
Never found an acuator so I replaced the whole turbo. Took care of the problem. Did you put a mighty-vac on your actuator to test it?
fanw01
Omaha, NE
2012 Passat SE tdi
I did test the actuator, the actuator does not hold vacuum. I know the actuator is bad but I really don't want to buy a new turbo for just a bad actuator.
After you replaced you turbo did you have any additional adjustments to make on the actuator? Do you know of a good repair manual for the VW? I have the Bentley Service manual.
ecaddy
Illinois
2006 Jetta TDI
I bought the turbo from a seller on ebay for $800 plus a $100 core. My old turbo is good so I will just sell the turbo without actuator on ebay and get more than what the core return is worth.
http://www.ebay.com/itm/300527554417?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Nice unit with no issues. The actuator bar was set at a different spot than my old one but they clearly marked it with red glue stuff so if I moved it they could tell. I left it alone and installed it that way. I then data logged it and this is what I got:
[FONT=&quot]
[/FONT]http://www.flickr.com/photos/78986143@N02/6981005126/
If you have a Bently manual you have a lot more than I had, which was nothing. It took a good 8 hours to do but it really wasn't that hard. Replacing the dmf was a lot worse. I pulled the turbo out from the top of the motor but it could be done from underneath also. I drove the car up on ramps and not jack stands so I was not able to remove the passenger side axle, that is why I went out the top. I can give some help if you have questions, I don't know how detailed the manual is.
I did not find any write up on the internet for the 2006 turbo removal, and I looked a lot for one. If you are located near me I would be happy to donate some time to lend a hand.
fanw01
Omaha, NE
2012 Passat SE tdi
[FONT=&quot]
Thanks for the information you have been a big help. I am going to purchase a new turbo for my car also. I don't want to fight with modifications to a turbo and EGR tube at this time. I was thinking of replacing the turbo with a Garrett turbo but at this time there is not a good match for a Garrett turbo with a smart actuator that would not require modifications to the smart actuator or EGR tube. I do know I will not pay the stealership $2700-$3300 to replace the turbo.
Thanks for the offer to help out but I live in Nebraska so not that close to Illinois. :)
Cliffman
Hollister, Ca
None Yet!
I'm having a very similar problem only I’m getting 2 codes. 1 is the P0299 Control Range Not Reached and the other is the P0102 Signal too Low – Intermittent. The P0102 is the MAF Sensor. When pulling a hill my 06 BRM goes in a “loss of power” mode. I don’t think it’s “limp mode” from what I’ve been reading. Limp mode is when your VW or Audi TDI suddenly loses power while driving and is restored after you turn the car off and back on. That is not my case. I do get a sudden lose of power but it’s not restored by a key cycle. In order to get power back I have to clear the code with a OBD reader. If I pull over and unplug the MAF the “loose of power” goes away and I’m back in business. From what I’ve been reading on this forum that tells me the MAF is bad. But before I go and buy the replacement MAF I want to make sure that is in fact the problem. The only thing stopping me is the PO299 Code but if the MAF is not working properly it will send a code to the computer putting it in a low power mode. I’m assuming the P0299 code is the lack of fuel caused by the MAF putting the computer in a low power mode. Does that make sense?
Ol'Rattler
PNA
2006 BRM Jetta
ecaddy
Illinois
2006 Jetta TDI
Do it yourself
There is no rebuild kit for the electronic actuator and there is not one available for purchase anywhere.
You are going to have to purchase the entire turbo and replacement.
Replace the turbo yourself, it is not difficult and you will save a ton of money.
You might as well do the egr mod while your at it, if you drop the turbo underneath the car you will have to remove it anyway. After you do the egr mod you will have to have Superchips do a mild level 1 mod on your ecu to keep the engine light off.
Good luck! Not hard but it will take a little time.
ecaddy
Illinois
2006 Jetta TDI
Chinese ??
Why would there be a core on a new part? Prothe? Chinese knock off/rebuild? Let us know if it grenades within 10 to 20K miles or so................
Yes, there was a core charge. Borg Warner doesn't make there turbo's in China now, do they?
I have 30k on the new turbo and no problems. Bought it off of eBay
ecaddy
Illinois
2006 Jetta TDI
Boost actuator
Check your boost actuator with a vacuum pump from the autopart store. Autozone sells one that will be perfect for what you are testing.
Cliffman
Hollister, Ca
None Yet!
I guess I should do the test just to rule it out but I don't see how that could possibly be the problem given the fact that when it goes into "wimp mode" (that’s what I call it cuz it's not "Limp Mode") all I have to do is unplug the MAF sensor and Whaaalaaaa, got all my power back. The boost actuator is a mechanical device that I don’t believe can be fixed by unplugging the MAF. Please correct me if I’m wrong.
scrichy84
St. Helens, OR
2006 Jetta, Manual
I hate to tell you, but you may have 2 issues. Your symptoms of a loss of power up hills does sound like the actuator. An easier way test, is have someone else start the car while you watch the actuator rod, if it extends slowly upon startup it is working, if it tries to extend and you have to help it down with a regular screwdriver it is bad. Your exhaust will also sound loud and airy at idle if it is broke. I drove around for 17k miles with it broke, and it didn't always go until limp mode up hills because shifting down to raise the rpm over 2200 would prevent it.
ecaddy
Illinois
2006 Jetta TDI
When you put the handheld vacuum pump on the actuator did the bar move and stay in that position? If you went right back then your actuator is bad and you will need to replace the turbo.
The actuator is electronic for the 2005 and 2006 Jetta TDI.
If you have a data cable that will give you some additional info that will be helpful. The Ross-Tech VCDS I use is very good. Post your logs if you need additional help
DanG144
2005 A4 Jetta 5spd
Actually the actuator mentioned in post #26 as not fitting WILL INDEED fit the 2005.5, 2006, 2007 Jettas. These cars have the BRM motors and require the expensive electronic position feedback vacuum operator pictured in the add from IDParts.com. When in doubt read the label on top of the timing belt cover.
But there is nothing to show he needs a new actuator, yet.
ecaddy
Illinois
2006 Jetta TDI
You are correct, after enlarging the picture it does look like an electronic actuator. Wish these were out when I needed them. At first glance it appeared to be a vacuum actuator and those will not work.
Cliffman
Hollister, Ca
None Yet!
I love to but the turbo seems to be hidden behind the engine. :eek:
