banshee365
Hey guy's. I think I've got an evap core leak on my 286k mile BRM Jetta along with a sticking RCV. The compressor was replaced at a dealer in 2013 or so by the previous owner. I don't have an AC machine so I have to take my stuff to a shop for that part of the work. I had them suck it down and recharge it as well as diag any leaks with a sniffer. They came back saying the only leaks were the two valves at the ports so they replaced those and charged it back up. They pulled like .5lb of refrigerant from the system and added the 1.16lb back to it. With the RCV sticking the air really didn't work any better and then I started noticing a refrigerant smell from the vents when you first turn on the blower. There really is any other way that I know of for that to happen other than a leak in the evap case.
I already have the RCV in hand from polar. I could pay to have the system sucked down, I replace the valve and then have it recharged and see how long it lasts but that seems like sort of a waste if I know the evap core is leaking somewhere. I've combed through the board a bit on evap cores in the MkV's and it seems they aren't very common to go bad. That makes me a little skeptical on going through this whole job but my nose isn't lying when it comes to the small when you first turn on the blower.
I wanted to get some opinions on what some others would do in this situation on whether to just replace the RCV and roll with it or go all out and replace the evap/expansion valve and RCV at the same time with one AC service fee rather than two at different times. I also have an RCD-330Plus coming in from China as well as needing to do the headliner. All of those can be done together because some of the labor and work required overlaps each other.
