fredjmillard
History (sorry for the long post)
I picked up a 2006 Jetta TDI with 93,000 from the original owner. The car has been serviced regularly at the dealer with the stamps in the book. At 88,000 miles a timing belt kit was installed by a 3rd party not the dealer. Shortly after the car was parked and driven sparingly. After sitting almost a year the owner decided to part ways. He bought a new battery, started the car and drove it to the carwash. After hosing down the engine back he could not get the car to start and thought it was electrical. The car is in fantastic shape other than some bubbling paint and the fact that it wont run.
Upon inspecting the car I found
Upon draining the oil and coolant,
Here is where it gets weird. I pulled the oil cap between trying to start and forgot to put it back on and the damn car fired right up and idled just fine, albeit with a a ton of blowby. As soon as I put the oil cap back on the car would die, which was also when I had to call it a night.
So what is known
Fred
- that the coolant bottle was empty with an oil residue
- the oil cap had milky oil
- the dipstick had gray milky oil.
- I would say roughly ~1.5 quarts of coolant came out first, then the milky oil out of the sump.
- The oil filter showed no signs of metal.
- The coolant was green but was a bright green and looked not to have pink
- There wasnt much oil in the coolant system
- Oil cooler pressure tested fine, but replace it anyway
So what is known
- Oil had a lot of coolant
- Coolant had some oil
- oil cooler pressure tested fine
- car only starts and idles if oil cap is off
- Compression, Bad rings bad head gasket, anyway to decern between the two with a compression check? does anybody know the proper fitting for the glow plug hole?
- Exhaust resricted? I dont think exhaust is going out the tailpipe but am not sure yet. I only say that because after cranking when i thought it was a fuel problem i sniffed the tail pipe and couldnt smell any fumes, but didnt check it after the car did idle.
Fred
