Hey everyone. Here’s the VCDS Data.
Sunday,30,January,2022,14:37:34:28589
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64)
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: 3VWNT71K56M689042 License Plate: ERIC
Mileage: 257970km-160295mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 36 42 44 46 52 56 62 72 7D
VIN: 3VWNT71K56M689042 Mileage: 257970km-160295miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H01--- Serial number: VWZ7Z0E2566212
Coding: 0050071
Shop #: WSC 66565 257 00032
VCID: 63C5EC69A23A15913C-8036
VINID: 0E69DE90705B14674620900408907391D3
1 Fault Found:
000258 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 257350 km
Time Indication: 0
Date: 2000.00.00
Time: 22:18:21
Freeze Frame:
RPM: 1386 /min
Speed: 0.0 km/h
Load: 0.0 %
Duty Cycle: 100.6 %
Bin. Bits: 00101111
Mass Air / Rev.: 305.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
Shop #: WSC 00066 000 00000
VCID: 3F8D00196E12117178-806A
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 DG
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 6CD787554FE45AE98D-8038
2 Faults Found:
00229 - Refrigerant Pressure
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000167184
Coding: 10018E234004180000140000001400000028770B5C
Shop #: WSC 91476 999 00150
VCID: 2B5544498A6A9DD1C4-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0402
Coding: 00065493
Shop #: WSC 91476
3 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 92
Mileage: 256135 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 3
Reset counter: 119
Mileage: 255787 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 10.15 V
OFF
ON
ON
ON
OFF
02381 - Windshield Wiper Motor; Overload
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 127
Reset counter: 125
Mileage: 257863 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.00 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD03ZW0R
Coding: 0012627
VCID: 2E534D5DB978E8F9E3-807A
Subsystem 1 - Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Subsystem 2 - Serial number: 6332MSME0A79264EN
Subsystem 3 - Serial number: 6342MSME0A6404196
Subsystem 4 - Serial number: 6351HSME0811460A/
Subsystem 5 - Serial number: 6361HSME08171B7EH
Subsystem 6 - Serial number: 63727SME077B5C6DL
Subsystem 7 - Serial number: 63827SME07742000O
3 Faults Found:
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - Intermittent - MIL ON
01218 - Side Airbag Igniter; Passenger Side (N200)
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
Component: J0527 034 0070
Coding: 0002021
VCID: 7AFBB10D35B0F4590F-802E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 007 0050
No fault code found.
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 872 D
Component: KOMBIINSTRUMENT 3HL 1212
Coding: 0024303
VCID: 2C5747558F649AE9CD-8078
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
010 - Open or Short to Plus
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001057288210
Coding: 3D7F0B400F1002
VCID: 2A5B414D859084D93F-807E
1 Fault Found:
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 92
Mileage: 256135 km
Time Indication: 0
Date: 2000.00.00
Time: 17:28:27
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1293324T0DTP01
Coding: 0000003
VCID: 39796E0170363F4146-806C
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 1212
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
Component: Sitzverstellung 0701
Revision: 00003000 Serial number: 00000000000000
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 3663653D4128D039AB-8062
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 326B592DAD40CC1987-8066
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 13900E880106281B0904050FB0080F0480A540
VCID: 020BC9ED5D60BC9957-8056
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
00930 - Locking Module for Central Locking; Rear Left (F222)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 4
Fault Frequency: 12
Reset counter: 112
Mileage: 255393 km
Time Indication: 0
Date: 2000.00.00
Time: 21:26:14
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 377D683946222931B0-8062
3 Faults Found:
00933 - Electric Window Motor; Passenger Side (V148)
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal - Intermittent
Address 56: Radio Labels: 1K0-035-1xx-56.clb
Part No SW: 1K0 035 180 D HW: 1K0 035 180 D
Component: Radio DE2 011 0014
Revision: 00011000 Serial number: VWZ4Z7E3049303
Coding: 0010400
VCID: 2149A661F8A647816E-8074
1 Fault Found:
00003 - Control Module
014 - Defective
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 31695621A846F701FE-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D514A51B47E93E1DA-8078
