TDiesel06
I experienced a second occurrence of PRNDS flashing from the DSG mechatronics 02E 927 770 AE. I've serviced the DSG filter and fluid, with OE parts, at 40k intervals since ownership. Once at 265,000 and then at 305,000 a couple months ago.
-The first occurrence was August 9th at night from a cold start which immediately set a fault PRNDS flashing and no reverse. It made the short trim home and onto the lawn. The next morning VCDS scanned 18145 - Transmission Solenoid Power Relay. I cleared the code and it stayed off. I was able to reverse. I did some web research and decided to clean the grounds under the hood that morning. One at the right headlight, one at left wiper arm, one at the right headlight including the transmission on both ends. Also the battery ground on the right shock tower. All were wire wheeled and installed with CRC electrical contact cleaner. I also pulled the harness off the transmission. I noticed it was damp with an oily residue, so I CRC'd and aired out the pins, then ensured that it secured back on. No codes came up for about two weeks. Voltage supply 1 and 2 both had 13-14 VDC present. I downloaded the VW DSG 02E self study pdf to get more familiar with the components. Also to note, the selector lever is showing all positions as it is shifted through the PRNDS range in VCDS.
-Second time was today after a 10 minute drive. It cold started fine, drove half way to my destination (2 mi.), came to a stop on my journey and shifted to P and left it running. When I returned one minute later the PRNDS was flashing.......I scanned it tonight with VCDS. VCDS results are below. I cleared the codes, but the fault returns and there's no reverse.
+ I plan to back probe the harness tomorrow to check input voltage at the transmission harness for the voltage inputs. It appears like it's time for a rebuilt Mechatronics. I'm really interested to find a reputable place to send the unit if you know a reliable rebuild vendor. I found a place in the UK that shows $370 + $50 return shipping Ecutesting.com
Code:
Friday,28,August,2020,19:55:07:03008
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64)
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: 3VWCT71K56M852151 License Plate:
Mileage: 494450km-307236mi Repair Order:
Address 02: Auto Trans Labels: 02E-927-770.clb
Control Module Part Number: 02E 300 043 HW: 02E 927 770 AE
Component and/or Version: GSG DSG 070 1126
Software Coding: 0000020
Work Shop Code: WSC 00066 000 00000
VCID: 51A350AEC8E2FA0ED4-8004
2 Faults Found:
19164 - Pressure Control Solenoid 6
P2732 - 000 - Implausible Signal or Stuck Off - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 255
Reset counter: 39
Mileage: 494450 km
Time Indication: 0
18154 - Transmission Solenoid Power Relay
P1746 - 002 - Electrical Malfunction - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Reset counter: 40
Time Indication: 0
Address 02: DTCs cleared
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.clb
Control Module Part Number: 1K0 959 701 P HW: 1K0 959 793 L
Component and/or Version: J386 TUER-SG FT 1127
Software Coding: 0001205
VCID: 3B7F12067A6E605E1E-806E
2 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 3
Fault Frequency: 7
Reset counter: 34
Mileage: 0 km
Time Indication: 0
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 6
Reset counter: 3
Mileage: 493991 km
Time Indication: 0
Address 42: DTCs cleared
Address 02: Auto Trans (02E 300 043 )
20:04:08 Group 005
P Selector Lever Position
Activated Starting enabled
13.50 V Voltage Supply 1
0.00 V Voltage Supply 2
