2005 NB Drivers Door Adjustment Up and Down
Stafford Virginia 22556
96 glx variant tdi
I'm trying to raise the entire door a few hairs worth to get the door and top seal to, well, seal. There is a small gap there now that can only be resolved by raising the door. Any ideas on what the secret is ? Mr. Bentley isn't too forth coming.
shoebear
Colorado Springs, CO
1998 Jetta, 2003 Jetta Wagon, 2005 New Beetle, 2013 Sportwagen
The door hinges are held on with XZN (triple square) bolts, if I remember correctly. Loosen those and you should be able to adjust the door however you like. But: unless you are very skilled, you will probably have to make the adjustment a bunch of times before you get it right, so be patient. Also, the bolts are in tight quarters, so you may need low profile XZN sockets. I have a set of these, which are ideal - but the set is pricey.
CARBYNE Bit Socket Set
