05TurboWagon
So... I went back outside, freezing my stones off, key on, ESP issue again. Re-AutoScanned:
Same errors for:
Address 01 (B1S1 o2 Sensor who cares)
Address 03 (ESP Front MK60 0102 Fault 01314)
Address 17 (KOMBI+WEGFAHRSP VDO V06 Fault 01314)
Address 19 (radio, who cares)
Address 46 (8A Komfortgerát HLO 0004 Fault: 00930 [rear right lock])
Here is some other info I gathered at SoT:
Address 01: Engine (038 997 016 H)
19:25:51 Group 004: Pump-Jet Valves
903 /min Engine Speed (G28)
9.3 °BTDC Injection Start (specified)
6.6°KW Injection Duration (specified)
2.5°KW Torsion Value
19:29:42 Group 010: Charge Pressure Control
385.0 mg/str Mass Air Flow (actual)
856.8 mbar Atmospheric Pressure
856.8 mbar Boost Pressure (actual)
0.0 % Accel. Pedal Pos. Sensor 1 (G79)
5.2 mg/str Injection Quantity
87.3°C Coolant Temperature (G62)
200.0 mg/str Exhaust Gas Recirculat. (spec.)
380.0 mg/str Exhaust Gas Recirculat. (actual)
100.6 % Exhaust Gas Recirc. Duty Cycle
5.0 °BTDC Injection Start (specified)
Address 01: Engine
Control Module Part Number: 038 997 016 H
Component and/or Version: R4 1,9L EDC G000SG 9970
Software Coding: 0150031
Work Shop Code: WSC 23329
VCID: 2313EF0617CE2ED34E0-5184
Advanced Identification
Serial number: VWZ7Z0D0917977
Identification: BPG-810
Revision: 12345678
Date: 01.12.04
Test stand number: 1889
Manufacturer number: 0847
Flash Status
Programming Attempts: 1
Successful Attempts: 1
Programming Status: 00000000
Required Conditions: 00000001
Flash Tool Code: 84223 444 23329
Flash Date: 00.00.00
Software
P0101
U+8A7
Misc.
Hardware number: 028 101 181 2
Car Info
Chassis Number: WVWSR61J65W063424
Same errors for:
Address 01: Engine
Revision: 12345678
Date: 01.12.04
Flash Status
Software
P0101
U+8A7
Misc.
Car Info
