So, after finally finding my HEX-V2 I ran an autoscan, results are as follows:
Code:
Tuesday,12,January,2021,16:45:35:48492
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201125 DS322.1
www.Ross-Tech.com
VIN: WVWSR61J65W063424 License Plate:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: WVWSR61J65W063424 Mileage: 539530km-335248miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 038 997 016 H HW: 028 101 181 2
Component: R4 1,9L EDC G000SG 9970
Revision: 12345678 Serial number: VWZ7Z0D0917977
Coding: 0150031
Shop #: WSC 23329 444 83999
VCID: 2313EF0617CE2ED34E0-5184
1 Fault Found:
17524 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 000 - Open Circuit
Freeze Frame:
RPM: 882 /min
Torque: 32.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Mass Air / Rev.: 290.0 mg/str
(no units): 0.20
(no units): 0.0
Bin. Bits: 11001001
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019458
Shop #: WSC 01266 785 00200
VCID: 34311C5AA220B96BA7A-5184
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
004 - No Signal/Communication - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 17 AIRBAG VW61 0108 0003
Coding: 12599
Shop #: WSC 01266
VCID: 270BFB1666F6C2F3128-513C
No fault code found.
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00118
Shop #: WSC 01266
VCID: 2F3B13364E069AB3DA8-5184
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 906 Q
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 15232
Shop #: WSC 00000
VCID: 3B2337668A7E7613660-513C
WVWSR61J65W063424 VWZ7Z0D0917977
2 Faults Found:
49-10 - No Communications - Intermittent
01304 - Radio
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01266
VCID: 70B9D04A93B8C54B832-513C
2 Faults Found:
01304 - Radio
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 8A Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 01266
VCID: 372B2B56B6565273828-4B1E
Subsystem 1 - Part No: 1C1959801A
Component: 8A Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802A
Component: 8A Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811A
Component: 8A Tõrsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812A
Component: 8A Tõrsteuer.HR KLO 0202
4 Faults Found:
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00930 - Locking Module for Central Locking; Rear Left (F222)
27-00 - Implausible Signal
00931 - Locking Module for Central Locking; Rear Right (F223)
End----(Elapsed Time: 04:58, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
Addressing issues, top down:
Address 01: Engine
I know the o2 Sensor is borked. I have a replacement, I'm just lazy and haven't done it... plus it's cold. Unless this will affect fuel trim and mileage, I don't much care.
I assume this is the ABS sensor for the passenger side - front?
While I was sick, I paid another guy to replace my turbo when it crapped out in Sept 2019 (never realized it threw a DTC, but didn't have VCDS at the time)
2 Faults Found:
01304 - Radio
I assume this is the dashboard tach? It does not register RPM until after the car starts. Afterwards, the gauge registers, as well as RPM reading on Torque Pro.
2 Faults Found:
01304 - Radio
I assume this is because I replaced the monsoon stereo with a Kenwood Excelon DDX9906XR with a PAC's RP4-VW11 to retain steering wheel controls. Does it matter much or do I need to get an interface to play nice with the canbus?
4 Faults Found:
The only thing that makes sense here is the rear left and right. The rear left lock goes up most of the time, but has issues going back down. The rear right goes up and down most of the time but gets stuck. I can only assume that the mechanism are dirty/unlubricated or they are dying.
It seems like the ABS sensor or possibly the tach would cause the ESP light to trigger on key on? I can also understand why, if the issue is actually the crank sensor, as to why there would be a failure to start.
However, what I do not understand is that, if the comms w/ the ECM were intermittent, why key on/off would "fix" this issue and allow the car to start. Furthermore, to see if the DTC's would pop back up, I cleared the all of them. When I did that, turned off the car, and disconnected vagcom/cable, I tried starting the car and it started IMMMEDIATELY like a damn champ. I took her for a spirited test drive; after I came home, I ran another scan... nothing but the o2 Sensor popped. Once she is good and icy cold, I am going to go start her up again and see what I can see, then take a VERY spirited test drive and scan again.
As far as the locks, do you think it would be worth while to take the rear doors apart and clean/lube the locking mechanisms, or simply replace them? I'm not sure what the deal was with the passenger-front locking mechanism nor the front left window regulator switch... both work like butter.
What am I missing? Could stored DTC's cause issues? If there are issues with the RPM gauge/crank sensor or abs sensor, would clearing the codes fix my issue, possibly to have them pop up later? Is there a way to test the ECM for failure status? I looked at my wiring, I don't think that is an issue. Could it be a ground I have since fixed? I'm currently more enlightened, but very much at a loss.
