Shenandoah
- Joined
- Jan 9, 2008
- Location
- Shenandoah Valley, VA
- TDI
- 2005 Jetta Wagon; 2005 Beetle; 2004 Jetta; 2002 Golf (three of them); 2002 Jetta Wagon; 2000 Audi TT->TDI; 1999 Beetle
Folks,
I started having problems with my 2005 Beetle last Winter. Once it got warm, it would suddenly quit. I could turn the key off, then restart it and it might run for ten minutes, or it might suddenly quit. I parked it and figured I look at it once it was warmer (I've got several VWs to choose from.....).
Today I tried starting it. It would just crank, but not start. I removed the fuel line to the fuel filter and cycled the key. I've got fuel coming out of the fuel line, so I know the lift pump is working. I also noticed the glow plug light was flashing when I turned the key to the on position.
I scanned with VCDS and saw the following codes:
19463 - Camshaft Position Sensor (G40)
17056 - Cylinder 2 Glow Plug Circuit (Q11)
18072 - Control Circuit for PD Injectors P1664 - 000 - Electrical Malfunction
I cleared those codes, tried starting it again. Same as before, crank but no start. I scanned again and get the following code:
16705 - Engine Speed Sensor (G28) P0321 - 000 - Implausible Signal
I am thinking of ordering a new PD BEW injector electrical harness and replacing that first unless someone has had a similar problem that was caused by something else? Or is there something else I should check or test? Thank you.
Eric
Eric
