toolmangary
I deleted the EGR on my wife's 2004 BHW, used block off plates and removed the cooler. When i started it up the transmission instantly when into limp mode (gear LED fully lite up) and set P1857 code - Load signal fault signal from ECU, and AllData says check MAF. Checking the MAF in data stream with my scanner, MAF has a target of 340 mg/s and actual of 455 mg/s.
So I'm guessing that the ECU must figure in the EGR flow at a idle because the MAF can't see the EGR flow because the flow is not going through the MAF. Now that the EGR is deleted, 100% of the air flow goes through the MAF
Does that make sense??
I can clear the code and as soon as I start the engine the P1857 code comes right back. I did check the carpet around the transmission control module and it is dry. I also tried a different MAF and it didn't change anything.
Do I need to get the ECU tuned and have the EGR deleted from it? If so what is my best option to have the tuning done, what tune? Sending the ECU to somebody isn't problem.
I've deleted the EGR's and coolers from other diesel engines before and never had a problem, even without a tuner.
Any thought, ideas, comments?
I need to fix this so my wife isn't driving my truck,
