Vegified TDi
Hi. A friend just got an apparent steal of a deal on a 2004 wagon. I read the CEL codes for him tonight. I noticed it idling high...around 1200-1400 RPM and wonder if that would contribute to the codes below. The VCDS log is below:
Address 01: Engine Labels: 038-906-016-BEW.lbl
Control Module Part Number: 038 997 016 R HW: 028 101 114 6
Component and/or Version: R4 1,9L EDC G000SG 0282
Software Coding: 0150031
Work Shop Code: WSC 91505 999 11172
VCID: 2D5FF581B738E870BBD
8 Faults Found:
18996 - Turbocharger Boost Control Position Sensor Circuit
P2564 - 000 - Signal too Low
Freeze Frame:
RPM: 0 /min
Torque: 306.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Lambda: -8.9 %
Absolute Pres.: 112.2 mbar
Absolute Pres.: 856.8 mbar
16502 - Engine Coolant Temp. Sensor (G62)
P0118 - 000 - Signal too High - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 306.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00101100
Temperature: -41.4°C
Temperature: 46.8°C
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault - Intermittent
Freeze Frame:
RPM: 1848 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 00101111
Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
Freeze Frame:
RPM: 1470 /min
Torque: 28.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00101100
Temperature: -29.7°C
Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Freeze Frame:
RPM: 1260 /min
Torque: 38.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.44 V
Bin. Bits: 00101100
Temperature: -16.2°C
Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault - Intermittent
Freeze Frame:
RPM: 1680 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 14.5 %
Voltage: 14.06 V
Bin. Bits: 00001000
Bin. Bits: 10110000
16500 - Engine Coolant Temp. Sensor (G62)
P0116 - 000 - Implausible Signal
Freeze Frame:
RPM: 2058 /min
Torque: 66.0 Nm
Speed: 51.0 km/h
Load: 25.1 %
Voltage: 14.67 V
Bin. Bits: 00001000
Temperature: -38.7°C
Temperature: 43.2°C
16515 - Oxygen (Lambda) Sensor B1 S1
P0131 - 000 - Signal too Low
Freeze Frame:
RPM: 903 /min
Torque: 270.0 Nm
Speed: 23.0 km/h
Load: 34.1 %
Mass Air / Rev.: 355.0 mg/str
(no units): 0.20
(no units): 0.0
Bin. Bits: 10001001
I am most curious about the non-glow plug codes. Are they related to the idle? The temp sensor related to the glow plugs?
Sorry for the general nature of the questions but I would appreciate any thoughts.
Torie
8 Faults Found:
Freeze Frame:
RPM: 0 /min
Torque: 306.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Lambda: -8.9 %
Freeze Frame:
RPM: 0 /min
Torque: 306.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00101100
Temperature: 46.8°C
Freeze Frame:
RPM: 1848 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 00101111
Bin. Bits: 10110000
Freeze Frame:
RPM: 1470 /min
Torque: 28.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00101100
Bin. Bits: 10110000
Freeze Frame:
RPM: 1260 /min
Torque: 38.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.44 V
Bin. Bits: 00101100
Bin. Bits: 10110000
Freeze Frame:
RPM: 1680 /min
Torque: 46.0 Nm
Speed: 0.0 km/h
Load: 14.5 %
Voltage: 14.06 V
Bin. Bits: 00001000
Bin. Bits: 10110000
Freeze Frame:
RPM: 2058 /min
Torque: 66.0 Nm
Speed: 51.0 km/h
Load: 25.1 %
Voltage: 14.67 V
Bin. Bits: 00001000
Temperature: 43.2°C
Freeze Frame:
RPM: 903 /min
Torque: 270.0 Nm
Speed: 23.0 km/h
Load: 34.1 %
(no units): 0.20
(no units): 0.0
Bin. Bits: 10001001
Torie
