Looking for some more help. 2004 BEW tdi has intermittent starting problem. Can be when warm or cold, sometimes it cranks longer then sputters like it’s not running on all cylinders then runs fine after a few seconds sometimes it just cranks and doesn’t start and most of the time it starts right up. Once it’s started it runs perfectly fine. I drive about a hour commute to and from school then to work and home every day. I have tried changing the Mass air flow sensor the crankshaft position sensor, has a new lift pump as of a month ago, replaced most of the seals on the intake tubes, replaced rubber fuel lines, new fuel temp sensor and have a camshaft position sensor that’s supposed to be here Wednesday to put in it. Today it would not start, and I tried a little bit of starting fluid (I know most will say it’s bad but it’s what I had to do) with that it fired right up and ran fine. The only codes are from the EGR that has been deleted and a Mass air flow sensor code still (scanned with vcds). The only other thing I can think of would the tandem pump any other ideas?
