2003 Wagon
BoiseTDI
Texas
2003 Jetta Wagon CURRENT, 2002 Jetta Wagon - SOLD, 96 Golf - SOLD
Slowing making OEM+ upgrades. 👌
Recently had a bunch of small parking lot dings removed (guessing about 30ish)…what an amazing job they did. Added 33% ceramic window tint all around, new lights (while I decide what to do with the original set, will probably sand down and polish them), monster floor mats, hood bug shield and lastly cleaned out the dreaded front fenders. Lastly had to add my Boise State License plate frames (not shown). =)
Next up:
Add Dieselgeeks full metal jacket skid plate (sitting in garage), IDParts Frostheater (sitting in garage), upgraded center console w/the cupholders (ordered), 16” bbs wheels (ordered), Ventectomy, double din radio.
BoiseTDI
Texas
By the way, does anyone have experience adjusting these lights?
Zak99b5
Albany NY
2003 Jetta TDI
The lights I have look identical to yours. Output was only marginally better than stock with halogens in them.
I put a DDM Tuning HID kit in them. Muuuuch better.
There are two adjuster screws on each headlight; one for vertical and the other for horizontal. Daniel Stern has comprehensive instructions for aiming any lights. All you need is dark, a wall you can put tape on, and level space to back the car up 25’ feet.
bigsexyTDI
Kentucky
'98 NB x2, '01 Jetta x2, '03 NB, '04 Jetta x2
Next up:
Holy crap thats a lot of crap... no wonder these things rust out there.
BoiseTDI
Texas
Did you check for the foam blocks in the front fenders? If they're there, take them out. They also cause rust. They're located at the very top of the wheel well, just behind the liners.
I did not, I will definitely look into this thank you.
Sting
VW TSB on the foam blocks says to cut 1/2" off the ends so they don't retain water against the metal. That has worked for me. Complete removal results in a subtle increase in NVH.
When you say the ends... the end that is in contact with the rocker, on the bottom of the foam piece? I cleaned mine out in the fall but if I can make this even better, I will.
P2B
Toronto & Muskoka, Canada
No, it's at the top of the wheel arch well away from the rockers. TSB here:
BoiseTDI
Texas
Added Frostheater
and restitched left driver seat. Not a pro job but it adds character and a few more years to the seat. 🙂
BoiseTDI
Texas
TrashtruckTDI
New Britain Ct
2003 Jetta Wagon
Ive thought about filling that debris collection area behind the fender with some kind of built up deflector but I know it will eventually fail. Probably won't be any worse than the moisture trapped up against it now.
