Entrance ramp to freeway going thru the gears to get up to speed. 3rd gear 4000ish RPM's engine makes a sound best described as Pppfffffffffffshtttttttt then black smoke. Shut engine off and coasted to the side of the road. Could not find any issues, nothing leaking. Restarted - engine sounded fine. Drove home...could hear turbo whine.....excessively loud turbo whine and lots of black smoke ONLY when you gave it too much accelerator. If you kept RPM's low you could drive with no smoke. Turbo sounded like a police siren. Boost was -.5 or -.05 and when driving it was -.07 or -.7 almost the entire time. Water temps were normal. I had scan guage to give me the boost numbers and lots of other numbers if they are necessary. No codes and no "pending codes" per scan guage. I have Vag com, too....unregistered. What else do you need to know? I have a 1.8T pancake pipe....
I could see the pancake pipe was still connected ok. Behind the engine I could see some oil but it did not look like it was new. nor was it everywhere. It was mainly on the black rubber pipe crossing behind the motor on the passenger side about the level of the pancake pipe.
