2003 Jetta Wagen just passed a million KM... now what?
ymz
Between Toronto & Montreal
Of course, the odometer went to all dashes... (perhaps that's why it's called a dashboard...)
Is there a not-terribly-expensive way to get something working in there? I know there used to be someone in the U.S. that could reset the clusters, but... we're in Canada, and with the border closed, it's not that easy to send things like this - even if I could locate the fellow (I heard he stopped doing this kind of work)...
What have others done?
Y.
csstevej
north nj
Wasnt that Jetta 97 that did cluster work?
STDOUBT
Portland, effing Oregon
dos jettas
Isn't there a way to switch the display to "miles"?
That would at least give you something to look at.
Congratulations, BTW! That's very very cool.
scooperhsd
Kansas City KS
NB, 2000, RED(5 Speed conversion) 2015 Golf SE
ymz
No... I have VCDS and can read the ECU from time to time... I'd love to get something that will resemble a functioning odometer / cluster... I know that just getting a junkyard cluster won't work due to the immobilizer issue... (I'm sure my friendly local VW dealer would be glad to assist, but... the car's not worth the money that would cost...)
scooperhsd
Kansas City KS
Some of the links on that had products that connected to the OBDII connector that might make it easier ....
scooperhsd
Kansas City KS
I'd have to check my ScanGuage II to see if it can display total miles from the ECU, I know it can display speed.
Johhny04
Markham, Ontario
2003 Jetta TDi
Y.
Congrats on hitting over 1 million.
There was a thread here a while back where someone was looking into a way to add non-volatile memory to the cluster, so it could add another digit in or something. But it may have just been applicable to cars with miles displayed, as ours stop at ~621k or so (whatever a million KM converts to). The cluster (and the whole car) "thinks" in Metric of course, but at the last second they have to convert it to miles for us knuckle-draggers here. The cluster itself I think may still continue to count, just like the ECU does, it just can no longer display it.
I believe the VAG-TACHO Chinese deal can rewrite the memory and put it back to zero, so you can at least start counting up again, since there is nothing "wrong" with your cluster.
Congrats on the milestone. I am not far behind with one of mine, I'm at 580k miles (about 934k KM).
ymz
Wow... you've done a ton of work... I got a headache reading your linked thread, but will return to it soon... I have a Hex-USB+CAN cable, and somewhere in the world I have an old serial clone cable (probably packed away with a laptop that hasn't worked in years...) I also have some other (major) maintenance items to do on the car first, but I'll keep this in mind! BTW: would the (VDO??) clusters in the German-produced cars (Wagons) behave in the same manner?
gmenounos
Watertown, MA, USA
'99.5 Golf GLS, '01 Jetta GLX Wagon (TDI conversion)
Hex-USB+CAN cable should work but you'll need to configure it as a Virtual COM Port: https://www.ross-tech.com/vag-com/usb/virtual-com-port.php
All of the Immo3 VDO clusters I've played around with store the mileage the same way and so can only count up to 1,048,575 km (65536 x 8 x 2- 1). I never knew what happens when you get to the point of "rolling it over" but I guess we now know.
  • Like
Reactions: ymz
CStone
East TN
2003 Jetta ALH 5sp.
I hit this milestone on my Jetta - didn't realize the odometer wasn't ticking over for several weeks. LOL. It would be nice to be able to track miles as this car is still my daily driver.
marcomurabia
MADRID
Mk7
Y.
