Helped a friend change his timing belt. The tensioner was the old B4 style with a tang that goes into a slot in the block at 10 oclock. The tensioner nut was tensioned to 15 lb/ft. Turned the tensioner clockwise to tension the belt. The tab was not centered in the notch on the tensioner, but the tab was in the notch, so it was close. He went for a 10 mile test drive and the now the tab on the tensioner seems to have moved and is outside the notch by a tiny bit. ***? I have done a couple dozen timing belts and have never seen this happen. Do we have a problem?
