davidm2232
I recently purchased a 2003 jetta, my first TDI. i really like the car but i am starting to hate it. i have a leak on the coolant outlet flange. i settled for an automatic as i had a deal on in, but i would much rather have a 5 spd. so, i am stuck with the plastic flange i have heard problems about. i was pleasantly surprised to find a new flange with o-ring for $15 including shipping. the part should be here today or tomorrow. sadly, this is not my only problem. my coolant system is getting pressurized. i can open the resivor and it will hiss after sitting all night. i can also run the car for less than a minute and it will be pressurized. i have come to the conclusion that it is most likely the EGR cooler and not the head gasket. how would i test this before i go through all the work to swap it out? my buddy did the egr delete, so i can get a working cooler from a 2000 jetta. are they the same part? will the exhaust over-pressurize my system, causing more leaks? thanks so much.
