2003 Golf ALH Crank No Start - Not another one!
rotaecho
Phoenix
mTDI AHU in an 82 Vanagon Diesel & 86' 1.6na Golf (destined TDI)
Sorry to be "that" guy, but I'm loosing my mind.
I have read the "no start" thread, I will give a little history then give what I've attempted.
I bought the Golf for my nephew's grad present. Going through it more so since 2d are rare in my parts so I just grabbed it. It did run though and I did drive it home. It had a busted hard heater line bent at a 90, EGR delete so no emissions, and A/C didn't work. I was told it had an air leak in the fuel system at the fuel filter; which looked stock/oe from car new.
The guy said he did the TB recently, I've done plenty of AHU/ALH TB's so wasn't unfamilar. The components were new, dated good, and only issue was VCDS had it way retarded which I corrected. So, fixed timing, and she started right up!
I then proceeded switching the engine mounts, replacing all the broken A/C components, replacing the broken hard heater line that wraps around the engine, new alt, and a bunch of other ****. I also had to reinstall the emissions that I got from another TDI (99 Beetle).
Finally got it all buttoned up, and she cranks, sounds like she wants to start; as I get more than a crank like a sputter. Won't actually start though.
The battery isn't the best, but it does hold a charge at 12.8v. I've also had it on the charger whlie I'm in VCDS or kill it cranking attempting.
What have I done to investigate.
** Verified Fuel Filter & IP are bled** I filled the new fuel filter with diesel. Pulled fuel from the filter housing and then again from the IP return with a mityvac. Cracked all four injectors and cranked till no bubbles.
** Intake & EGR/Emissions appear proper/functiong/clean.
** The Anti_Shudder Valve installed with the EGR appears to function properly.
**VCDS*** I first fired it up and cleared any DTCs from all the previous running and work now. I then attempted to start and go the following. All of which seem fine and nothing to prevent a no start; I know about the passenger seat. Nothing stood out with VCDS.
Thanks for any suggestions. Getting a testlight and checking the fuel solenoid; be odd it just went out though during this work.
*** VCDS LOG****
Log the abs sensor and passenger seat is all known stuff at moment (seat is out)
Monday,29,May,2023,14:49:40:16246
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 22.9.0.0 (x64)
Data version: 20220830 DS341.0
www.Ross-Tech.com
VIN: 9BWBP61J734078521 License Plate:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: 9BWBP61J734078521 Mileage: 634980km-394558miles
Address 01: Engine Labels: 038-906-012-AGR.clb
Part No: 038 906 012 GN
Component: 1,9l R4 EDC G000SG 4308
Coding: 00002
Shop #: WSC 00001
VCID: 62C5B9ADEE70C79D35-4B18
9BWBP61J734078521 VWZ7Z0C7129691
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00001 785 00200
VCID: 336B0CE9510A1E158E-515A
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 08 AIRBAG VW61 0202 0003
Coding: 12344
Shop #: WSC 00001
VCID: 2753E8B9C5D262B522-513C
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 L
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 07232
Shop #: WSC 00001
VCID: 316706E1FB162C05FC-513C
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00001
VCID: 70E1C3E5309C650DB3-513C
1 Fault Found:
01304 - Radio
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 8B Komfortgerát HLO 0003
Coding: 00064
Shop #: WSC 00001
VCID: 377338F91572F235B2-4B18
Subsystem 1 - Part No: 1C1959801A
Component: 8B Tõrsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C1959802A
Component: 8B Tõrsteuer.BF KLO 0009
End-------------------------(Elapsed Time: 04:47)--------------------------
jokila
Houston, Texas
2003 Jetta GLS, Manual
Do you hear the click at the IP when the ignition switch is powered up?
Does the glow plug light work on ignition switch power up?
Johhny04
Markham, Ontario
2003 Jetta TDi
I would switch battery to a healthy one that you know is strong to give you a good crank. Also check Fuse #90?? (black square one, the new ones are grey colored) the one under the steering column that usually goes and doesn't allow for a start. I know i'm not naming the correct fuse but hoping others can chime in.
Vince Waldon
Edmonton AB Canada
Perhaps you've done this, but you can confirm cranking speed with VCDS, which, if present, confirms the ECU is running and sees the crank sensor.
rotaecho
Phoenix
I saw this too late, but this was on the right track!
I noticed no RPMs on the tacho, so looked at the crank sensor connector next to the IP connector. Sure enough, it wasn't seated enough to where it clicked.
I clicked it in and now the car starts.
Thanks all!
