2003 Beetle
Tdijarhead
Lawrenceville PA
Pull the tail light housing, remove the bulbs, tighten up the sockets so the bulbs set in the sockets tighter.
This assumes you have power to the rear socket?
Have you checked the fuses?
Diesel Brain
moncton
2001 jetta 2003 Beetle
Yes,pulled every fuse and did a visual check. Also checked every fuse with an ohm meter. I am going to swap out the headlight switch tomorrow.
