79TA7.6
- Joined
- May 8, 2006
- TDI
- 2003 Jetta GLS 5 Speed
A little history first. I have owned my car since 85k miles. It currently has 288k. I change the gear oil every 50k, the last 150k has been with Penzoil Synchromesh. About 150k ago I installed a Dieselgeek short shifter. I drive this car 140 miles per day, usually 4 days a week. The route I take has me down shifting from 5th all the way to 3rd about 30 times per day.
Now for my issue. I started having issues up shifting into 4th about 50k ago. If I double shifted, rev matching, it would go in fine. Eventually I had issues down shifting into 4th as well. The last 25k or so the same is happening with 3rd. It is at the point that I cannot down shift into 3rd or 4th with out rev matching. I was thinking it might be the synchros, but the reading I am seeing on the forums this does not sound like the case. It sounds like synchros will just flat grind while going i to gear. Is this the case? I tried to readjust the shift linkage a while back and that did nothing. I think the linkage is all good. If it is not the synchros then what could it be? I am at a loss and am really tired of it. It is a real pain when I am driving down my 5.5 miles of gravel soggy road and have to down shift. It usually does not affect me on the gravel, but with it being as wet as it is and climbing hills, it takes a lot of power, which requires me to down shift.
Anyone got any ideas for me? Could it still be the synchros?
