TDIRyan
I may be getting rid of the dub to get a tow vehicle if I can find the right buyer:
It's a:
2002 TDI GLS Auto
Black on Black cloth
NEW:
Timing Belt and all pulleys
armrest
vacuum lines (blue silicone)
coolant temp sensor
glow plugs
cross-drilled rotors up front and regular Zimmerman's on rear with Mintex Reds
coolant migration mod
elephant hose mod (CCV) (will come with original CCV hose attached)
REPLACED UNDER WARRANTY (last year):
fiber optics in shifter
AC condensor
brake booster
Accessory belt and tensioner
INCLUDED:
Alpine 9847 head unit
20% tint with "Fast" tinted in rear window
Rocketchip Stage 2
PP357 Injectors
18" Motegi MR7 wheels with P-zeros up front and Parada Spec 2's in rear
Avus 15" with 90% tread tires (came on it)
GLI front lip
Tinted tail lights
Alientech Window Controller
Newsouth VDO boost and EGT gauges (EGT not tapped,but comes with)
Boostvalve
Snow screen delete
Rocketchip Stage 2 with PP357 injectors (another TDIclub member dyno'd this setup at 274Ft/Lbs @ the wheels) and can easily spin the 18's. The transmission is smooth as glass and the car runs beautifully. I did show it last car show season till I came across the Chevy, so it's pretty much immaculate. If anything gave me issues at all or was questionable, it was replaced. This car has also never seen a salted road. It was a Florida car before I got it.
I don't have them on, but the engine cover and original wheels come with as well. I also will give the original steering column top that I replaced with the gauge pod.
NADA value: $13,800
ASKING: $14K WITH ALL MODS LISTED
please PM me or contact me if you want more info/pics. Some of these are older (engine does not show elephant hose or vacuum lines)
It's a:
2002 TDI GLS Auto
NEW:
armrest
coolant temp sensor
glow plugs
AC condensor
brake booster
INCLUDED:
Rocketchip Stage 2
PP357 Injectors
GLI front lip
Tinted tail lights
Boostvalve
Snow screen delete
NADA value: $13,800
