Thirstyturtle328
SOLD SOLD SOLD
Price: $4,500 $4,300 $4,100 $4,000
Model: 2002 Golf TDI GLS
Mileage: 278,000
Transmission: 5-speed manual
Exterior color: Black
Interior color: Black (cloth)
For sale here is a 2002 VW Golf TDI GLS. This is the ALH engine with the 5-speed manual transmission. Car has AVERAGED 47mpg over the last 100k miles with multiple tanks of 50mpg+ and over 700 miles. Vehicle has 278k miles but is in very good mechanical condition. I have meticulous service records for the last 120k miles (since I've owned it). Car blew a timing belt right before I bought it and was rebuilt (details below in maintenance history) - has run flawlessly since. I bought this car when I had a long commute and drove a lot for work but now I work a mile from my house and have a dedicated work vehicle so I've moved on to a newer car. This is the absolute highest mileage car in the US other than MAYBE a Prius which is not as much fun to drive I assure you.
Power windows, door locks, and mirrors. Defrost side mirrors. I have one keyless entry remote/key and one separate key so two total.
Car is black with black cloth interior. Paint is in decent overall shape with some scratches and minor dings. Long straight scratch down passenger side from a garage incident. Hood and front bumper are the worst parts of the car - lots of paint chips on bumper, a few rust spots on hood and clear coat fading badly. Overall I give the exterior a 6/10 but 8/10 given the age and mileage. Interior is a 7/10 but 9/10 given the age and mileage.
After being put on the lift recently for the new tires, the full extension if the shocks caused them to seize since they were about 100k miles old. As a result, the car currently rides very rough - up until that point it's always been very smooth and comfortable. The struts and shocks will need to be replaced.
Everything works on this car and there are several extras:
-Audi Fat Five 17x7.5" wheels
-iPod/Bluetooth adapter for stock sound system
-Trailer hitch and wiring harness
-Roof rack crossbars
-Panzer plate (aluminum "skid" plate to protect oil pan)
-Retrofit Bi-Xenon HID projector headlights w/ 4500k bulbs (white, just like high-end vehicles, not blue)
-FrostHeater block heater
-BRAND NEW tires (Hankook Ventus S1 Noble 2, 224/45-R17)
-520 Bosio Injector Nozzles
-New center console w/ cup holders so the front has 4 cup holders (two in dash, not broken like most are)
-Rubber floor mats
Service Records:
31,250: Front Driver Wheel Bearing Replaced, Headlight Bulb Replaced, Alignment Checked, Steering/Suspension Checked
69,125: Vehicle Serviced
73,943: Vehicle Serviced
80,032: Vehicle Serviced
147,529: Brakes Replaced, Brake Fluid Flushed, Oil and Filter Changed, Caliper Replaced
152,025: Vehicle Serviced
162,250: Brake Light Switch Replaced, Sunroof Drain Hoses Repaired, Battery Replaced
***164,000: Timing Belt, Water Pump, Upper Roller, Lower Roller, and Large Roller Replaced. Coolant Replaced. Snow Screen Cleaned. Oil and Oil Filter Changed. Fuel Filter Replaced. 520 Sprint Bosio Nozzles installed. New Valves, Guides, Seals, and Lifters. Head re-worked.
165,000: Cabin Air Filter Replaced. New Tires. New Center Console. New Shifter Boot. New Windshield Wipers.
167,000: Engine Air Filter, New Armrest
174,600: Oil Changed, Front Brake Rotors and Pads Replaced, Front Passenger Wheel Bearing Replaced, EGR Oil Leak Noted
177,200: Front Brake Rotors and Pads Replaced
180,500: EGR Replaced
184,400: Replaced rear shocks
185,300: New Wheels, 225/45R17 Continental ExtremeContact DWS Tires, Oil Changed, Oil Filter Changed, Fuel Filter Changed
194,700: Oil Changed, Differential/Transmission Fluid Changed (G070)
195,500: Tires Rotated
196,500: Rear Springs Replaced
199,800: Front struts, strut mounts, strut bearings, ball joints, and control arms replaced. Alignment performed.
201,000: Wheels Balanced and Rotated.
215,000: Passenger tie-rod replaced, alignment performed
225,000: Oil and filter changed (Mobil 1 TDT), fuel filter changed
231,642: A/C flushed and recharged, was 6oz low
231,800: Large cooling fan replaced
232,000: New tires (225/45-ZR17 Hankook Ventus S1 Noble2)
234,000: Replaced AC compressor, drier, evacuation and recharge
235,800 (9/27/14): Oil Changed (Mobil 1 TDT 5W-40)
***238,000 (10/24/14): Timing Belt, water pump, upper roller, lower roller, idler roller, tensioner, and serpentine belt replaced. Coolant flushed. Front brake rotors and pads replaced. Front caliper slider pins and bushings replaced. Brake fluid flushed.
238,500 (11/5/14): Oil supply hardline to turbo replaced with custom stainless steel braided hose
247,200 (3/1/15): Oil and filter changed (Mobil 1 TDT 5W-40), fuel filter changed.
248,500 (3/18/15): Diesel Kleen
249,000 (3/29/15): Small vacuum hoses replaced
257,000 (8/12/15): Oil and filter changed, engine air filter replaced, thermostat changed
261,000 (10/25/15): Driver side axle replaced, passenger side parking brake cable replaced
263,000: FrostHeater installed
265,200 (1/13/16): Starter motor replaced, oil and filter changed, fuel filter changed.
270,000 (5/14/16): Rear brake rotors and pads replaced, rear driver's caliper replaced
274,307 (2/1/17): Oil and filter change, brake fluid flush
276,650 (4/11/17): New tires (225/45-ZR17 Hankook Ventus S1 Noble2)
277,000 (4/23/17): Alternator and pulley replaced, injection pump seals replaced, upper radiator hose replaced
278,000 (7/11/17): New battery installed, cleaned cable terminals.
Quickest way to get me is email - mattcarlisle@gmail.com
Scratch (hitch carrier was leaning against car and my wife drove it forward like 8 feet so it's a nearly perfectly straight scratch):
Mileage: 278,000
-Rubber floor mats
Service Records:
